How to remove dashboard sections.
   / How to remove dashboard sections. #1
DEWFPO
Veteran Member
"Up High in the Rockies"
2009 Bobcat Toolcat 5600 D
I want to remove the two light gray plastic dashboard sections on my 2009 Series D. I don't see any clips or fasteners above or below. Maybe it's a snap fit. Can someone point me in the correct direction?
Thanks, DEWFPO
   / How to remove dashboard sections. #2
Did you get them off?
No I didn't. I got under there to take another look and it looks like the plastic dash pieces (at least the driver's side) is bolted to metal brackets that bolt to the frame. I only saw one bracket underneath to the left of the steering column, but I'm sure there are more that I just couldn't see. There's got to be an easy way to get it off. It looks **** near impossible and I know that can't be the case.
DEWFPO
   / How to remove dashboard sections. #4
I checked the service manual for my Series F, no mention of the dash. It does show how to remove the black center display panel. There is a tab on each side that you push in while pushing up on the panel.
Why do you need to remove it?
2 reasons. I want to add a new switch to the dash for a back-up camera/monitor and wire it into the reverse circuit. Also, I want to add a voltmeter to the dash.
DEWFPO
2013 John Deere 4730 Self-Propelled Sprayer (A51039)
2013 John Deere...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
Brent 420 Grain Cart (A50514)
Brent 420 Grain...
2015 DODGE RAM...
2019 Harley Davidson (A50324)
2019 Harley...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
