How to rebuild a Bush Hog Rotary Cutter gearbox.
   / How to rebuild a Bush Hog Rotary Cutter gearbox. #11
Like a very easy job, if bearings are ok then it's the seals and other throw away parts that is necessary. I guess it's quite loose fit so it should come a part quite easily.
Yep. Thanks to your excellent parts illustrations!!!
To the OP. DO NOT USE A PRESS!!!
Study the drawings. Disassemble piece by piece. You have to remove the horizontal shaft first. Then the vertical shaft.
   / How to rebuild a Bush Hog Rotary Cutter gearbox. #12
   / How to rebuild a Bush Hog Rotary Cutter gearbox. #13
I've rebuilt automatic transmissions decades ago, this gearbox is way too easy!..
   / How to rebuild a Bush Hog Rotary Cutter gearbox. #14
Just went through this with a JD MX6 with broken output shaft. JD Parts has good parts assembly drawings that might be helpful to you. I bet they go together similarly.
I wound up with around $800 repairing broken parts and said if had to do over again would replace the gear box with a new one for around $500. The gentleman that does welding for me helped with it. He works on cutter decks and gear boxes often and recommended next time to just replace the gear box....all new parts then. I wound up having to buy a $100 shim kit from JD to get the gears to not lock up.
   / How to rebuild a Bush Hog Rotary Cutter gearbox. #15
Looking at your Bush Hog specs, my Woods looks very comparable. I wonder if the gear boxes are interchangeable? Maybe someone with more knowledge than me can answer that. But if the spline diameters are the same and the 6 bolt pattern the same, It may work. I believe this one cost around $600 and is rated the same as yours. IMG_1665.JPGIMG_1666.JPG
   / How to rebuild a Bush Hog Rotary Cutter gearbox. #17
Suppose its hard to loosen nut on outgoing shaft, you may pull out the cover 22 on the draving, remove circlips and force out the PTo shaft out together with the front bearing
this makes sense!. the shafts would come out from the inside to the outside.. just opposite as you would imagine they are inserted.. nuts and circlips removed, of course.. just keep an eye on the clearances when assembled. just changing a shaft won't affect that, changing a gear would though.. separate the parts for the input and output shafts so no mistakes are made, you don't want to mix up spacers, especially..
   / How to rebuild a Bush Hog Rotary Cutter gearbox. #18
Good point concerning shims. They are there to correct imperfections in the case castings. They need to go back in exactly the same place.
Thanks all. I am continuing to learn from your replies. My parts will be here Monday, but I won't be back in town before Wednesday. I looked at non-OEM replacement boxes and found some in the $3-500 range. I can match the input and output shaft specs, but the Comer box is six bolt vs. all of the ones I have found which are four bolt. If I am unable to repair the box, which I think unlikely, I will try the best "wrong" gearbox I can locate. The rest of the box looks very good. Bearings are all smooth and there is no wear showing on the gear faces. Seals are even good at the moment. I bought some extra shims in case they end up needed to get the backlash to spec. I'll need to order seals for the input shaft. I thought about a used hog in the same price range, but mine would have looked just like it before the gearbox went TU. I felt better starting with the running gear known to be good.
For forensics, it looks like a weld broke on the top of the stump jumper hub where a welded piece thickens the splined section on top of the blade crossbar. Once the weld broke, the entire mower force was taken only by the bottom have of the splined hub that was part of the blade crossbar. A couple (or a couple of hundred - I don't know how long it has been broken) of good stump / rock hits and the shaft broke at the top of the splines and ejected the blade assembly into the field. The weld breaks look very old. No fresh metal showing.
   / How to rebuild a Bush Hog Rotary Cutter gearbox. #20
Good luck. Keep us informed. The Woods I bought is a 6 bolt. If you decide to go that route, I will look up the number and cost.
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2015 GMC 3500 HD 4x4 Crew Cab Pickup truck (A55973)
2015 GMC 3500 HD...
