How to rabbit-proof large garden?
   / How to rabbit-proof large garden? #12
You have to lay another fence on the ground, outside the fence and tie it together and anchor it to the ground with staples sold for this purpose.
It will keep out rabbits, but it's mostly used to keep out coyotes. They try to dig under the fence, but hit the wire that they are standing on, and they cannot get through.
   / How to rabbit-proof large garden? #13
12 ga. rabbit stew!
Only after the first hard frost! I think a 12ga might be a little overkill...a .22 or even a pellet gun should work.
   / How to rabbit-proof large garden? #14
Hasenpfeffer...!
   / How to rabbit-proof large garden? #17
I solved my gopher problem by making cages from hardware cloth and planting my maters and peppers in them.
   / How to rabbit-proof large garden? #19
I did something similar to keep a dog in a dog pen. I split sheets of corrugated metal roofing length wise to, save money, and burried them 6 inches deep under the bottom of the fence which was also set into the trench. Around 4 inches went to the outside of the fence and the greater portion on the inside. The sheet metal was not attached to the wire. Whether it was luck or not, I don't know but, the pup never got out.
   / How to rabbit-proof large garden? #20
What I found works well for me is to take chicken wire and only bury it about 4" but turn it out flat for about 18". They start digging at the fenceline and hit the horizontal wire. The are not smart enough to back off 18" to dig.
We used plastic mesh around the bottom 1ft high around the outside and turned it out about a foot. Seems to work as they don't dig and probably don't like walking on the mesh material maybe.
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
LEE G550 MOTOR GRADER (A51242)
LEE G550 MOTOR...
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
BROCE BROOM RCT350 SWEEPER (A51242)
BROCE BROOM RCT350...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
