How to rabbit-proof large garden?
   / How to rabbit-proof large garden? #1
lhfarm
Central Indiana
NH TC40DA
Have a 50' x 50' enclosed garden area. Woven fence 8' height because of heavy deer population. Been in place 25 years and need to straighten corner posts and replace wire fence. Deer are not a problem, but past several years we have rabbits digging under the fence in many places. I patch the hole and they just move on. If I replace all the fence wire, I want to stop the rabbits. What are the best bottom fence options and how deep do I need to bury?
Thanks,
   / How to rabbit-proof large garden? #2
I have used chicken wire with 1" holes and wires that to the existing chain link fence that seemed to work, but we didn't have rabbits that dig much.
Just though as I was typing, why not get a lawn edger and make a groove in the ground and bury pole barn steel in to about a foot or two. Install that as close as possible to the fence on the outside, kind of like skirting on a trailer house.
   / How to rabbit-proof large garden? #3
   / How to rabbit-proof large garden? #4
Build a rabbit garden outside with plenty of carrots to entice them away.
or
As my father did, label the plantings STORRAC in case the rabbits could read.
   / How to rabbit-proof large garden? #5
I used to have an 83' x 103' garden; no deer problem but the cottontails did take a liking to it. And now I've forgotten who told me to spread Blood Meal around the perimeter and the rabbits wouldn't cross it. I was a bit skeptical, but it worked for me. Of course Blood Meal is a high nitrogen fertilizer so it made the grass grow beautifully around the garden, and when it rained, that would water it in and I'd reapply it.
   / How to rabbit-proof large garden? #6
An electric fence wire about 3" off the ground will work, but you have to use weed killer to keep the grass from shorting it out.
   / How to rabbit-proof large garden? #8
What I found works well for me is to take chicken wire and only bury it about 4" but turn it out flat for about 18". They start digging at the fenceline and hit the horizontal wire. The are not smart enough to back off 18" to dig.
   / How to rabbit-proof large garden? #9
I have heard that you could just lay 8 or 10 in of chicken wire on the ground and staple it down with big staples made of stiff wire. Make sure not to leave a gap at the bottom of the fence. The best might be to turn it up onto the fence a little and then out from the fence on the ground. Hope this helps. Ed
   / How to rabbit-proof large garden? #10
I used to have a problem with rabbits in the veggie garden. It's 50x50 also. I added 18" chicken wire to the bottom of the fencing. That worked well. The larger garden stayed open and only got nibbles occasionally. I think with the increase in hawks and eagles around, the rabbits stay under cover. I loose more plants to gophers than rabbits. So goes the cycle of nature. :confused3:
1994 FORD F450-SUPER DUTY FLATBED (A51222)
1994 FORD...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A52128)
2022 JCB 3TS-8T...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2016 MACK GU713 GRANITE DUMP TRUCK (A51222)
2016 MACK GU713...
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
2015 Dodge Challenger Coupe (A50324)
2015 Dodge...
