How to pull gas tank on "48 A?
   / How to pull gas tank on "48 A? #1
BarryinMN
Platinum Member
Minnesota
JD, Allis-Chalmers, Zetor
How to pull gas tank on \"48 A?
What is the best process to pull this?
I have to re-solder the seam due to leakage.
Thanks
   / How to pull gas tank on "48 A? #2
Re: How to pull gas tank on \"48 A?
Have not had to do mine. Seems that once the hood is out of the way, there is only a few bolts holding it on, and of course the gas line. Do you have a battery box or hydraulics that might block things?
Mine is a'41 A.
Powr Trol is out back & battery is under seat.
   / How to pull gas tank on "48 A? #4
I'll look clsoer at mine tomorrow. You might also cross post to ytmag.com on the Farmall discussion board.
   / How to pull gas tank on "48 A? #5
I think he's got a JD 'A'.. not a farmall 'A'
Powertroll is a JD version of a precursor to the standard 3pt hitch we have today... etc...\
To the fellow with the 'A'.. I have a 'B'.. looks like it would come out as follows:
As for removing it.. once sheet metal is gone, and bands / bolts are loose / gas line gone.. should be piece of cake.
Might try a tank sealer.. like por15.. or even an epoxy rated for gas tank repair ( they have both gas tank repair sticks, and battery repair stickes..etc.. ).. try it.. you might get lucky.
Soundguy
   / How to pull gas tank on "48 A? #6
I used to have a JD M and the tank leaked. After finding out a new tank was $60, I took it to a machine shop where the guy cut out the leaky tube in the bottom and welded in a new one. Cost was $10!
Worked great for me and the new owner years later.
Best Wishes,
Ron
City of Buckhannon - 2000 GMC 3500 Service Truck (A52384)
City of Buckhannon...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
TMA (A49461)
TMA (A49461)
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
2020 Bell TC-11A Crawler Carrier (A52384)
2020 Bell TC-11A...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
