How to pull gas tank on "48 A?
   / How to pull gas tank on "48 A? #1
BarryinMN
Platinum Member
Minnesota
JD, Allis-Chalmers, Zetor
How to pull gas tank on \"48 A?
What is the best process to pull this?
I have to re-solder the seam due to leakage.
   / How to pull gas tank on "48 A? #2
Re: How to pull gas tank on \"48 A?
Have not had to do mine. Seems that once the hood is out of the way, there is only a few bolts holding it on, and of course the gas line. Do you have a battery box or hydraulics that might block things?
Mine is a'41 A.
Powr Trol is out back & battery is under seat.
   / How to pull gas tank on "48 A? #4
I'll look clsoer at mine tomorrow. You might also cross post to ytmag.com on the Farmall discussion board.
   / How to pull gas tank on "48 A? #5
I think he's got a JD 'A'.. not a farmall 'A'
Powertroll is a JD version of a precursor to the standard 3pt hitch we have today... etc...\
To the fellow with the 'A'.. I have a 'B'.. looks like it would come out as follows:
As for removing it.. once sheet metal is gone, and bands / bolts are loose / gas line gone.. should be piece of cake.
Might try a tank sealer.. like por15.. or even an epoxy rated for gas tank repair ( they have both gas tank repair sticks, and battery repair stickes..etc.. ).. try it.. you might get lucky.
Soundguy
   / How to pull gas tank on "48 A? #6
I used to have a JD M and the tank leaked. After finding out a new tank was $60, I took it to a machine shop where the guy cut out the leaky tube in the bottom and welded in a new one. Cost was $10!
Worked great for me and the new owner years later.
Best Wishes,
Ron
City of Buckhannon - Power Curber 5700 (A52384)
City of Buckhannon...
2012 John Deere 7230R (A53473)
2012 John Deere...
City of Buckhannon Onan 450 Set Stand By Generator (A52384)
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
BUYERS PREMIUM & PAYMENT TERMS (A54313)
BUYERS PREMIUM &...
2007 International 4300 Dump Truck (A51691)
2007 International...
