How to mount a breaker box here?
   / How to mount a breaker box here? #1
drg1
Missouri
1532 hydro
Putting in electrical, and trying to figure how to put the breaker box in.
1 mount it to the purlins or
2 build a stick wall between the post and mount it there
Any suggestions or pics would be great
   / How to mount a breaker box here? #2
I would mount a 2-3' wide piece of 3/4" plywood to the purlins and make it tall enough to get up to the top of the wall so that you can run wires and/or conduit down it.
Aaron Z
   / How to mount a breaker box here? #3
You did not mention what it was for, but I would suggest over sizing it. You will be glad you did later.
   / How to mount a breaker box here? #4
Not sure what kind of building this is. But i have done similar by installing a 24" x24" piece of 3/4" plywood on the horixontal 2x6 and mounting panel. Then i run all wires up to ceiling height inside 3/4" schedule 80 PVC pipe.
The building is a pole barn, planning on a 200 amp service
   / How to mount a breaker box here? #6
Since you have the wood purlins, I would get a piece of plywood about 3 feet wide that will span the distance between the two purlins so that when installed the breaker box top will be about 6-7 feet from the floor level.
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2016 WABASH RFALHSA 53FT REEFER TRAILER (A54607)
2016 WABASH...
2015 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2015 Ford F-350...
2016 Ford Taurus AWD Sedan (A53424)
2016 Ford Taurus...
2024 CATERPILLAR 289D3 SKID STEER (A52705)
2024 CATERPILLAR...
UNUSED LANDHONOR LHR-RF24 RATCHETS & TOOLBOX (A54757)
UNUSED LANDHONOR...
