How to mount a breaker box here?
   / How to mount a breaker box here? #1
drg1
Missouri
1532 hydro
Putting in electrical, and trying to figure how to put the breaker box in.
1 mount it to the purlins or
2 build a stick wall between the post and mount it there
Any suggestions or pics would be great
   / How to mount a breaker box here? #2
I would mount a 2-3' wide piece of 3/4" plywood to the purlins and make it tall enough to get up to the top of the wall so that you can run wires and/or conduit down it.
Aaron Z
   / How to mount a breaker box here? #3
You did not mention what it was for, but I would suggest over sizing it. You will be glad you did later.
   / How to mount a breaker box here? #4
Not sure what kind of building this is. But i have done similar by installing a 24" x24" piece of 3/4" plywood on the horixontal 2x6 and mounting panel. Then i run all wires up to ceiling height inside 3/4" schedule 80 PVC pipe.
The building is a pole barn, planning on a 200 amp service
   / How to mount a breaker box here? #6
Since you have the wood purlins, I would get a piece of plywood about 3 feet wide that will span the distance between the two purlins so that when installed the breaker box top will be about 6-7 feet from the floor level.
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2007 Honda CR-V SUV (A53424)
2007 Honda CR-V...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
Freightliner Tender Truck (A55301)
Freightliner...
