How to mount a breaker box here?
   / How to mount a breaker box here? #1
drg1
Missouri
1532 hydro
Putting in electrical, and trying to figure how to put the breaker box in.
1 mount it to the purlins or
2 build a stick wall between the post and mount it there
Any suggestions or pics would be great
   / How to mount a breaker box here? #2
I would mount a 2-3' wide piece of 3/4" plywood to the purlins and make it tall enough to get up to the top of the wall so that you can run wires and/or conduit down it.
Aaron Z
   / How to mount a breaker box here? #3
You did not mention what it was for, but I would suggest over sizing it. You will be glad you did later.
   / How to mount a breaker box here? #4
Not sure what kind of building this is. But i have done similar by installing a 24" x24" piece of 3/4" plywood on the horixontal 2x6 and mounting panel. Then i run all wires up to ceiling height inside 3/4" schedule 80 PVC pipe.
The building is a pole barn, planning on a 200 amp service
   / How to mount a breaker box here? #6
Since you have the wood purlins, I would get a piece of plywood about 3 feet wide that will span the distance between the two purlins so that when installed the breaker box top will be about 6-7 feet from the floor level.
2023 Club Car Carryall 700 Utility Cart (A54811)
2023 Club Car...
PALLET OF SCAFFOLDING (APPROX. 19 PC) (A52706)
PALLET OF...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
