How to make governor more effective?
   / How to make governor more effective? #1
brotherjohn
central Florida and northwest Alabama
YM1510D
I'm running a PTO generator on my YM1510D for the coming himacane, but the governor does a lousy job of maintaining speed control when loading and unloading. Is there any way to make it more effective?
   / How to make governor more effective? #2
I don't know the answer to your question but I wish you and yours the best of luck with the "himicane".
   / How to make governor more effective? #3
That was my question on my 3110. You could hardly tell a difference when the governor kicks in .I had a gas burner b-4 my yanmar diesel & you could tell the difference when governor kicked in. I was told by a diesel mechanic that governors on diesels don't operate that way.So, I left it at that & hadn't asked anyone else. Good luck !! I don't mean good luck it in a bad way .
   / How to make governor more effective? #4
I'm confused. :confused:
"Tell a difference" in what? Engine RPM?
If that's it, isn't that a very good thing? A governor should hold the engine at a constant RPM as the generator loads and unloads - or, at least my impression was that's the primary function of a governor.
   / How to make governor more effective? #5
How big is your generator?
You've got a little less than 15 HP available at your PTO. A HP is about 750 W. So with perfect efficiency you've got about 10 to 11 KW available. But you're not going to get 100% efficiency.
If you're drawing much over 5 to 7 KW from the plant, I'd suggest that the tractor is underpowered for the load and no governor can or will keep the RPM up under those conditions.
   / How to make governor more effective? #6
The difference I'am talking about is mostly in the sound of the engine reving when the governor kicks in.Like in the different sound in a small gasoline engine generator .
Year: 2008 Make: International Model: 4300 Vehicle Type: Truck Mileage: 141781 Plate: Body Type: (A51692)
Year: 2008 Make...
2013 INTERNATIONAL REEFER TRUCK (A53426)
2013 INTERNATIONAL...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
