How to make FEL work slower?
/ How to make FEL work slower? #1
ulflyer
Bronze Member
lexington nc
CK 30H
Is there any way to make the FEL on my CK30 operate slower? When picking up mulch, or back dragging gravel in my driveway, for ex, I'd like it to function much slower. Is there some sort of hydraulic attachment that could be switched on/off?
/ How to make FEL work slower? #2
You can throttle down. They also make flow restrictors that can be installed but I would think you’d want that installed all the time. Is anything wrong with your end loader? I’ve never seen one you couldn’t feather at least a little bit.
/ How to make FEL work slower? #3
I have the exact same tractor. When doing delicate work I rest my palm against the fender and hold the lever below the grip. You need to keep the revs up so that the tractor has the power to do the job that you’re trying to do…
/ How to make FEL work slower? #4
Is the joystick or valves sticky? Maybe shave down the detent so you don't have to push as hard to get it off center? I find the one on my tractor is pretty good, like I can feather both lift and curl at the same time with some concentration, so maybe do some parts numbers comparison and see if the DKSE one fits. Throttling down a little helps too, but you don't want to be working the HST hard at low rpms.
/ How to make FEL work slower? #5
I would say you have a control issue. Stabilize your arm, as Robin Veerman says. Something you learn when operating 100' ladder trucks from the basket.
When I am hauling something heavy and it inadvertently lifts the rear wheels, when I want the loader down, I want it down now.
Don't think there is anything wrong with the loader. Can't see that it has changed over the years.
I think what I'd most like slower is the lift. Just seems to work too quick to control when dragging, for ex, where the surface is uneven.
I don't use it a lot and as mentioned by others I need to work on putting my hand lower. A shorter stick would work better for me.
I'm going to try throttling down when dragging driveway gravel. Never thought to try that. Thanks.
Good idea. Will try that.
/ How to make FEL work slower? #9
I would think you'd want the opposite. A longer lever would be less sensitive to a given amount of hand movement.
/ How to make FEL work slower? #10
I've been looking into something like this for my CX. Not for the lift though, for the lower function. Its way too fast sometimes and engine RPM has no affect on the lower speed.
/ How to make FEL work slower? #11
If the speed the loader lowers is the issue, you could install an adjustable one way flow restrictor. This would give your a way to adjust the speed the loader lowers but would still let it raise at full speed.
/ How to make FEL work slower? #12
Increase the stick length, that way you'll have to do larger movements for more precise work. Your stick isn't binary, on or off, but rather you can do small movements to have reduced speed.
/ How to make FEL work slower? #13
Where would you get something like that? My loader's a little bit faster on lowering than I'd like too.
/ How to make FEL work slower? #15
Surplus Center, Summit and I'm sure any place that sells hydraulic parts.
Get the adjustable one as you can adjust it to exactly what you want, which may vary depending on the task you're doing.
You'll need a one way or unidirectional flow restrictor and couple of fittings. Install it on the hose that would normally lift the loader, so the free flow direction goes to lift the loader at full flow but the restricted flow direction controls the speed the loader lowers.
Something along these lines: Hydraulic In-Line Adjustable Variable Flow Control Valve w/ Free Reverse Flow, 3/8" NPT
/ How to make FEL work slower? #16
Slow and smooth, like a trigger pull.....
Learned while maneuvering my 60 air compressor by myself.
Listen to the engine and hydraulic pump sound.
As soon as you feather the joy stick the hydraulic pump pitch changes, now you know the FEL is engaged.
Continue the feather action until you are satisfied with the progress.
Takes just a bit of practice, but it'll be a new operator skill enhancement.
/ How to make FEL work slower? #17
When I back drag my dirt driveway I put the loader into 'float' and use the bucket curl function and cutting edge to do the work.
