how to level deck on 520H?
   / how to level deck on 520H? #1
monkers
I noticed the deck on my 520H seems to tult down quite a bit in the front. How do I go about leveling it? There isnt anything in my owners manual about doing it. Its a 1989 520H with a 48" side discharge deck. There is a linkage rod on the rear of the deck with a nut on it that looks like it is an adjustment but I would like directions before I start messing around with it. Thanks
   / how to level deck on 520H? #2
Yes the rod will level your deck.I put mine on a flat surface and with a level on the deck bring it in so the front is just down a little from the back.
Great, thank you! That tie rod is the only adjustment used? Which hole di you have the chain connected to on the lift arm underneath, the front hole or the rear?
   / how to level deck on 520H? #4
Not sure off hand.I can check later when I get to the barn,
Thank you for your help, i think mine is in the front hole of the lift arm
CAT CHALLENGER 65B (A53843)
CAT CHALLENGER 65B...
Adams 8 Ton Weigh Hopper (A53473)
Adams 8 Ton Weigh...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
GENERATOR (A53843)
GENERATOR (A53843)
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
2013 John Deere 650K LGP (A47477)
2013 John Deere...
