How to Install a 60g Compressor?
   / How to Install a 60g Compressor? #22
Many thanks for all the ideas. Really did not want to put holes in the floor because I it's ugly and I may want to move the compressor to a different spot in the future. I think I'll just leave it on the pallet its shipped with and perhaps one of those large hard rubber mats from TSC under the pallet. Also, thinking I may (depending on what the shipping pallet looks like) build a better wooden base or set more blocking in the shipping pallet. And of course, make a more accessible drain. thanks again for all of the ideas...
Both mine (bought 10 yrs apart) came on substantial Oak pallets, they are 80 gal, but doubt if the pallets are much different.
   / How to Install a 60g Compressor? #23
I'd read the owners manual.
You may find that leaving it on the pallet without bolting it down will void your warranty.
   / How to Install a 60g Compressor? #24
And how would that be determined unless
(1) the owner was foolish enough to admit it or
(2) there was an onsite visit by the manufacturer's warranty dept staff.
Neither is likely, especially #2.
   / How to Install a 60g Compressor? #25
If the damage was caused by the unit toppling I think the case could be made.
   / How to Install a 60g Compressor? #26
If it fell over under any circumstances it would not be covered under any warranty I would expect to have. No more than if a building collapsed on it while it was firmly anchored to the floor. Warranty considerations as related to anchoring is a non-issue in my estimation.
   / How to Install a 60g Compressor? #27
i have one and its bolted to the floor on isolation pads. it took all of 20 minutes and a rotohammer to secure it, so why not. if i ever have to replace it i can sawzall off the lugs and do it over again.
   / How to Install a 60g Compressor? #28
I have a 60gallon horizontal mounted on skids... not much chance of toppling over.
The 60 and 80 gallon verticals I have installed at work are all seismically anchored... I just can't risk not doing it right in a hospital environment. I also live in a seismically active area along the Hayward fault so secure installations are standard procedure.
   / How to Install a 60g Compressor? #29
So you condone fraudulent claims?
   / How to Install a 60g Compressor? #30
Mine is sitting on vibration pads and has not moved. i used flex conduit for eletrical and hydraulic hose to run air to the wall where the regulator is located. It has worked fine.
Ditto X 2 (along with RickB).......:thumbsup:
2013 CHEVROLET SILVERADO 2500HD (A50854)
2013 CHEVROLET...
71068 (A49346)
71068 (A49346)
KLEIN TOOLBOX (A50854)
2000 SPARTAN SUMMIT RV (A50854)
2000 SPARTAN...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
