How to hook up a woods backhoe to a CK20???????
   / How to hook up a woods backhoe to a CK20??????? #1
Slackdaddy
Land of the Free
Kioti CK20HST
I have a CK20 and a woods 7500 backhoe,, biggest mistake (Woods)
Anyhow,, I for the life of me can not figure out how to hook the dam backhoe to the tractor.
Tractor has the woods sub frame kit.
The 3 point arms are right in the way,, and as usual, the woods instructions are no better the something from China.
Many thanks to anyone that can help out,
Slack
   / How to hook up a woods backhoe to a CK20??????? #2
I think you take the 3 point hitch arms off
   / How to hook up a woods backhoe to a CK20??????? #3
I had a Woods hoe on my CK-27 and really liked it. I always took off the 3 pt. arms and left the hoe on for ballast unless I was using the 3 pt.
   / How to hook up a woods backhoe to a CK20??????? #4
Slack
I have a 2003 CK20h, at that time the "factory" backhoe was supplied by Rhino. It's a 6.5 ft uses the subframe and mine has the PTO hydraulic pump and tank.(highly recommend, I can out dig a tractor beyond hydraulic at 1/4 throttle)
You MUST remove 3pt hitch arms. The hoe mounts under center by sliding a cross bar into 2 notches, the rear mounts into a notch under draw bar and whole thing is held in place by 2 3/4" pins. T probably have over 500hrs on hoe with no problems. Hope that helps. Joe48
   / How to hook up a woods backhoe to a CK20??????? #5
I had a CK30 with the Kioti backhoe and subframe. There was no need to remove 3pt arms to install this BH. I now have a DK40 with the Woods BH, with the Woods BH I need to remove the 3pt arms to get them out of the way before I can put the Woods BH on. It is only 2 bolts and 4 pins to remove the arms, takes less than 5 min.
1990 LOAD KING BELLY DUMP (A53843)
1990 LOAD KING...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2018 FREIGHTLINER BUCKET TRUCK (A51406)
2018 FREIGHTLINER...
2020 KUBOTA RTV...
2013 Ford E450 Shuttle Bus (A53117)
2013 Ford E450...
