How to hook up a woods backhoe to a CK20???????
   / How to hook up a woods backhoe to a CK20??????? #1
Slackdaddy
Gold Member
Land of the Free
Kioti CK20HST
I have a CK20 and a woods 7500 backhoe,, biggest mistake (Woods)
Anyhow,, I for the life of me can not figure out how to hook the dam backhoe to the tractor.
Tractor has the woods sub frame kit.
The 3 point arms are right in the way,, and as usual, the woods instructions are no better the something from China.
Many thanks to anyone that can help out,
Slack
   / How to hook up a woods backhoe to a CK20??????? #2
I think you take the 3 point hitch arms off
   / How to hook up a woods backhoe to a CK20??????? #3
I had a Woods hoe on my CK-27 and really liked it. I always took off the 3 pt. arms and left the hoe on for ballast unless I was using the 3 pt.
   / How to hook up a woods backhoe to a CK20??????? #4
Slack
I have a 2003 CK20h, at that time the "factory" backhoe was supplied by Rhino. It's a 6.5 ft uses the subframe and mine has the PTO hydraulic pump and tank.(highly recommend, I can out dig a tractor beyond hydraulic at 1/4 throttle)
You MUST remove 3pt hitch arms. The hoe mounts under center by sliding a cross bar into 2 notches, the rear mounts into a notch under draw bar and whole thing is held in place by 2 3/4" pins. T probably have over 500hrs on hoe with no problems. Hope that helps. Joe48
   / How to hook up a woods backhoe to a CK20??????? #5
I had a CK30 with the Kioti backhoe and subframe. There was no need to remove 3pt arms to install this BH. I now have a DK40 with the Woods BH, with the Woods BH I need to remove the 3pt arms to get them out of the way before I can put the Woods BH on. It is only 2 bolts and 4 pins to remove the arms, takes less than 5 min.
1782 (A57192)
1782 (A57192)
JOHN DEERE 35D EXCAVATOR (A52707)
JOHN DEERE 35D...
UNUSED 1RANCH 1RIG-13' 14' BI-PARTING IRON GATE (A57193)
UNUSED 1RANCH...
2019 Hitachi ZX300LC Hydraulic Excavator (A55851)
2019 Hitachi...
(2) Safemack 18.4-38 Tires w/Rims (A56469)
(2) Safemack...
2013 Infiniti G37 Coupe (A55853)
2013 Infiniti G37...
