Rear Blade How to grade a driveway? Need help please
   / How to grade a driveway? Need help please #11
...My 2 track driveway...
So we are talking about the same thing here... There's Grass in the middle of 2 rows of gravel or is it just 2 rows of dirt???
Do you want to keep the grass? if that's what you mean by "2 tracks"... let us know...
   / How to grade a driveway? Need help please #12
You have been given good advise. To repeat it: Angle the blade so it isn't paralell with the troughs and pull material to the center of the road. Cut a little at a time. Go slow and keep your hand on the blade height control. Try to cut just the high places off first. Pick up and lower the blade so it does not deepen the dips and cuts the high places. You will not get it perfect on the first couple passes, only better each time. When you've made some loose material back up using the back of the blade to make it flat as posible by filling the dips. The flatter it gets the easier it will be to make it better because your tractor wont rise and dip.
The only thing I can add is that you must be patient. It will take several passes especially when you are learning. Try working on just a 100 foot stretch to develope your technique and get a feel for how it will go. Working the entire 1000 feet might seem overwhelming when your confidence is low.
   / How to grade a driveway? Need help please #13
I think what my problem was years ago, was I didn't realize how important it was to have lose stuff to work with an the time it took to get the driveway all looking soft an workable.
A drag is what I use mine is a flatbed trailer frame.The cross members pick up an drop soft while the side rails keep the hole thing level.
You can try adjusting the angle of the blade to keep it from digging in or not cutting at all. also swing it on as long as angle as you can get to clear the wheels.
I just did my drive an graded it for a day, then after a few weeks dragged it an had some #57 spread, an dragged that. really worked great, also added several runoff to help get water off drive.
Also split the wheel tracks going an coming in it will help keep everything flat.
Good luck it just takes practice,an time.
Army Grunt
   / How to grade a driveway? Need help please #14
Might also wan't to try using your loader bucket tilted down while driving in reverse. Basically what ever you can do to knock off the bumps and smooth it out to start with. I say this because the Frontier 5' rearblade is very light and you can use the fel and get more weight to work with. If you can knock down some of the bumps then gradually set the front bucket closer to flat you can get the drive fairly smooth. Or atleast a better starting point to use the rearblade as mentioned by others.
With your 2520 which has some pronounced bends and angles in the hitch arms I would not use a rearblade, boxblade or any heavy implement with the tractor in reverse.
When we say go slow we mean to move slow enough you have time to react with the hitch controls, most noobies attempt to go faster than they can control the rear implement. Stop if necessary and adjust the hitch and continue a little at a time.
As others have mentioned a landplane/grader is the tool of choice for this work, I would save some coins for one in the near future.
   / How to grade a driveway? Need help please #15
Running and operating any rear blade is a talent that takes time to learn. As stated play with angles, top link adjustments and go slow and you well learn.
Anyone can run a blade ... an operator can perfect his level of skills ... also devolpe an "eye" and you'll be able to see where its high and where its low. Just takes time to learn.
Thanks again for everyones advise! This site is great. :thumbsup: It was a 2 track, but I did grade the center of the two rows out, I just want everyone to know it is fairly narrow drive. Any other tips would be great. It sound like I need to look for a good used Landplane.
   / How to grade a driveway? Need help please #17
The best graders have a center mount blade. They aren't nearly as touchy as the grader blades on either end of your tractor. Most tractors have a float option and this helps. Try using the blade to loosen your material then find something heavy you can drag behind the tractor. This will drag the material around to fill in the ruts and holes. Then use a drag chain behind your tractor to give it the finish look. pick any rocks bigger than your fist. Rolling it is optional at this point. This will punch down the bigger rocks.
   / How to grade a driveway? Need help please #18
Also as mentioned earlier, your blade should be angled and drag your material from the outside edge to the center of the road. You want to try to keep a moderately high crown in the road center. This will encourage water to run OFF the road and will keep you from getting washboard and pot holes. I have a farmal cub with a center grader blade that works awsome for moving material around after I have already loosened it up with my 1050. I also use a chaindrag hooked onto the back of the cub so I can move material around and give it a "finish" look at the same time.
   / How to grade a driveway? Need help please #19
If you can weld or have a friend that can help you out you can build one for about $400+ to fit your tractor. I built this larger 8' landplane for about $950 with straight set blades for landscape work. For driveway work I would use the angled blades which is more common. Long skids help overcome the problem with the dips you are experiencing. I plan on building a small 4' plane for my x749 in the next month or so and will post some pics of the build.
   / How to grade a driveway? Need help please #20
I know it is a pain, but try grading while driving backwards as your wheels will be on relatively flat surface which will eliminate the YO-YO effect.
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
Ratchet Straps (A55852)
Ratchet Straps...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2011 Ram 1500 4x4...
Utility Trailer (A52377)
Utility Trailer...
