HOW TO GET YOUR TRACTOR TO TURN OVER
   / HOW TO GET YOUR TRACTOR TO TURN OVER #1
Williy
Elite Member
Texas
Yanmar YT 235C Yannar YRC 60 rotary cutter, Yanmar RT72 rotary tiller B75 Backhoe & bucket & thumb, LS land grader
willy
   / HOW TO GET YOUR TRACTOR TO TURN OVER #2
I've heard of people doing that but it always seemed like a good way to get a tractor on your head. I have used the trick of putting a chain through the tire and backing up, which is a slightly safer way to do it.
   / HOW TO GET YOUR TRACTOR TO TURN OVER #3
I remember dad chaining logs to the wheels of his F-20. He layed logs on ground in front of tires. He ran ropes through pulleys to the clutch and brakes then drove it like a mule. It was spooky when the old tractor reared up like a horse but it got the job done. I saw the hand crank get away from him a couple times and be slung out.
He did tip the tractor over on his head.
He would have been ok with shorter logs
that would only extend about a foot beyond
the tire I have seen this way done with shorter
ones
willy
   / HOW TO GET YOUR TRACTOR TO TURN OVER #6
Just drive the tractor backwards and it can’t flip.
   / HOW TO GET YOUR TRACTOR TO TURN OVER #7
Should have used the clutch when it started to rise.
Bruce
   / HOW TO GET YOUR TRACTOR TO TURN OVER #8
ones
willy
I didn't realize it was a video, using a phone for this is less than optimal.
ROCKWOOD ULTRALITE 5TH WHEEL CAMPER (A52708)
ROCKWOOD ULTRALITE...
3PT PTO POST HOLE DIGGER (A52708)
3PT PTO POST HOLE...
(4) 225/65R17 USED TIRES (A58374)
(4) 225/65R17 USED...
SARLO MOWER (A55758)
PALLET OF BANISTER RAIL, MOLDING (A58374)
PALLET OF BANISTER...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
