How to get this %$#&% stump out???
   / How to get this %$#&% stump out??? #11
Use a strap, not a chain, and pull it out with your truck.
   / How to get this %$#&% stump out??? #12
I agree with the others that cutting is the safest way to get the rest of it out. Too much risk to the foundation if you keep digging at it with the backhoe.
I wouldn't hesitate to use a brand new chain on my chainsaw to get it out. Buying another chain isn't all that bad, especially to get it done and over with.
I also have several pruning blades for my Sawzall. I've used them on roots and smaller stumps. It just takes longer because you have to take it apart a little at a time.
   / How to get this %$#&% stump out??? #13
Looks like part of the tap root has grown under the building and is in that hard red pan. Probably have to dig under the root to get to it. Good luck. If you get it out, I would put gravel and hard pan up in there and pack it good.
Not sure if that is the best advice but a rotting stump might cause the building to sink as well? Not sure, but I like getting all the stump I can.
   / How to get this %$#&% stump out??? #14
Another thought, it is close enough to the corner, I might try working on it with my loader bucket from the right side. Like just kind of sawing on it from underneath, back and forth to cut or loosen it up.
Might at least help work it loose from the surrounding dirt so you can get at it with the saw, explosives or whatever.
   / How to get this %$#&% stump out??? #15
You would be surprised how well a chainsaw cuts dirt(not rocks). I have a little plastic saw with the 3/8 narrow round corner chain, and I try to cut with the top of the bar, to shoot the dirt out if I can. It's done a few stumps and sharpens up not bad still, I just file by hand, half way through if necessary and the chain seems to last quite a while. It just gets used for small jobs as it never did cut 12"+ hardwood well, but that's done with a different saw. If you have a pressure washer or even a hose you can clean the stump up a bit and not cut quite as much dirt.
   / How to get this %$#&% stump out??? #16
I can't imagine how you would be able to get any kind of decent compaction if you tried to excavate the root from under the building and then replaced the dirt/gravel. Personally, I would rather lop it off at the foundation line, and take the chance that the foundation would be able to bridge over any decomposed roots that are left. Probably would be a good idea to compact the he!! out of the fill dirt that goes back in the hole.
   / How to get this %$#&% stump out??? #18
Like others have said - cut it as low as you can, toss/sharpen the saw chain/blade after. No need to dig it out...
I know you said it's dead, but coat the remaining stump with Tordon/similar. Then bury it and forget about it.
I had a bunch of fairly big trees around (like RIGHT AT) the pole barn walls, when I bought the place. I just cut them at ground level and left 'em to rot (4 years later - they're still there and solid...).
   / How to get this %$#&% stump out??? #19
Many times I use a pickax and narrow shovel to expose roots then cut roots using shovel, hatchet, or ax. I've dug a lot of stumps.....grrr. Not fun.
   / How to get this %$#&% stump out??? #20
I had a few right up against the house foundation. I cut down most of what was there, left a foot or more to chain onto. I used a large come along strapped to a large tree at the base of it. I'd go out and give it a pull once or twice a day, after a few days or more," poof" the roots came out.
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
2011 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A56129)
2011 FREIGHTLINER...
2019 ISUSZU NPR BOX TRUCK (A56129)
2019 ISUSZU NPR...
2012 Freightliner M2 Chipper Truck (A52377)
2012 Freightliner...
2010 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A56129)
2010 MITSUBISHI...
Reel Mower (A55851)
Reel Mower (A55851)
