How to get this %$#&% stump out???
   / How to get this %$#&% stump out??? #21
Like others have said - cut it as low as you can, toss/sharpen the saw chain/blade after. No need to dig it out...
I know you said it's dead, but coat the remaining stump with Tordon/similar. Then bury it and forget about it.
I had a bunch of fairly big trees around (like RIGHT AT) the pole barn walls, when I bought the place. I just cut them at ground level and left 'em to rot (4 years later - they're still there and solid...).
Just go up to it and tell it you are going to split it with a maul and it will be petrified by the time you get back from the tool shed.
   / How to get this %$#&% stump out??? #22
I had cut down and slowly killed the roots of some small arborvitae that someone had planted in front of the windows here (I didn't have the tractor then). I have since noticed little sinkholes where they were. As someone mentioned above, this could be a problem for the shed.
Personally, I would leave it, cover it back up, and just prune any growth that comes back.
I've pulled incredibly heavy things with that 4x4 truck. It wouldn't move 1/4". Must be all those roots growing under shed concrete floor.
Problem solved!
My friend & neighbor is an excavator and I could see him putting equipment away. He said no problem and drove one smaller excavator over. It just took a few minutes and he said he digs out much bigger stumps but whatever this is was tough!
I hand dug smaller roots out, hauled everything off and filled & packed dirt back in with my tractor.
2015 CATERPILLAR 930M WHEEL LOADER (A52706)
2015 CATERPILLAR...
Ryobi Sliding Compound Miter Saw (A54865)
Ryobi Sliding...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
(2) GOLF BAGS W/ CLUBS (A54757)
(2) GOLF BAGS W/...
MULTIQUIP WHISPERWATT MQ POWER 25 GENERATOR (A52706)
MULTIQUIP...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
