How to get clay out of backhoe bucket?
   / How to get clay out of backhoe bucket? #11
It seems like someone could invent something like a thumb that would set inside the bucket and then push the clay out when dumping.
This is the idea behind chain option in the above post.
Don’t pack it by cutting it more with the teeth instead of scooping it out like normal. Think more along the lines of peeling an onion. Takes a little longer but once you get the hang of it it isn’t as bad. Better than trying to get packed clay out. Basically braking up the clay as you are digging it out
It seems like this would work well when you are digging up fairly dry clay, but my clay is so damp and gooey that it just sticks back together again.
I'm having trouble visualizing how the chain method is set up.
   / How to get clay out of backhoe bucket? #14
This is from another thread.
   / How to get clay out of backhoe bucket? #15
It is something. I had saw before. I have never went through the trouble myself but it will bust out the clay when you extend the bucket all the way out by tightening the chains.
   / How to get clay out of backhoe bucket? #16
Would a strong coat of linseed oil help? Sure seems to help with packed ice/snow on loader bucket.
   / How to get clay out of backhoe bucket? #18
Here is a pdf with pictures and instructions from another member (fisherridge) 7 years ago;
by fisherridge
I found this somewhere.​
   / How to get clay out of backhoe bucket? #19
Can you add more water to where your digging? I found that there is a certain amount of moisture in the soil that makes it extremely sticky and hard to get out of my bucket. WHen it dries out, there isn't a problem, and when there is standing water in the hole, there isn't a problem. I don't have a solution that works for those times that it just wants to stick to everything other then putting more water in the hole and dealing with it being muddier.
   / How to get clay out of backhoe bucket? #20
Cut (or burn/drill a few 1'') holes in the bucket to release suction. (imo, best shortcut, NO sacrifice later when digging dry mat'l.) ...
Yes. :thumbsup:
They make a "CLAY BUCKET" that is just basically a bucket without sides. That's the spend a lot of money option. Works the same as onion peeling method.
Yes. :thumbsup:
DIY bucket mod if you can. Use a 'Silver and Deming' 1/2" - 1" drill bit if that's all you got to drill 'suction relief' holes. (HFT, report!) Two-four holes should do it. My past experience with 15 ton Erie dragline crane and 1/2 yd bucket taught me much. :cool:
Journeyman metal worker says low RPM and water coolant will do best to drill 'big' holes. (>1/2") 'Chip' generated will always tell you when pressure and rpm are right. (Go slow, push hard .. ;))
This one should/could be easy for you. If it's not a 'piece of cake', keep asking. t o g
2023 KUBOTA SVL97-2 SKID STEER (A52705)
2023 KUBOTA...
2013 International TerraStar Enclosed Service Truck with Liftgate (A53422)
2013 International...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
UNUSED LANDHONOR SGB-11-72W 72" GRAPPLE BUCKET (A54757)
UNUSED LANDHONOR...
(3) CAT PALLET JACKS (A54756)
(3) CAT PALLET...
