MarkV
Super Member
- Joined
- Apr 7, 2000
- Messages
- 5,698
- Location
- Cedartown, Ga and N. Ga mountains
- Tractor
- 1998 Kubota B21, 2005 Kubota L39
I’ll second Eddie’s suggestion for the easiest way to get the finish profile you want. With the thin veneer brick you can attach then directly to the concrete foundation without having to form up a brick ledge and your sill plate will be bearing on the concrete foundation rather than partly on the brick. I also think the way you show it in your drawing you will not pass code on the foundation. The thickness of a full size brick with mortar is 4” which leaves 11/2” for the concrete if you want the foundation to be the width of a 2x6.
MarkV
MarkV
