How-to ?- foundations
   / How-to ?- foundations #1
weesa20
North Carolina
My house has a block foundation with a brick veneer. I want to build an attached garage with a poured foundation with a brick veneer on the stem walls and slab floor. I don't know how to figure out the thickness of the walls to accomodate the brick. Also, does this require 2x6-8 framing to accomodate the width of the wall and the bricks? Do the anchor bolts go through the sill plate and the bottom plate or just the sill plate? What holds the sill plate to the bottom plate if the bolts don't go through both? (I call the sill plate the piece of pressure treated wood that sits directly on the foundation and the bottom plate the piece that the studs are connected to that sits on top of the sill plate)
Thanks for any help.
W
   / How-to ?- foundations #2
Stick frame homes with brick vineer on a slab foundation is what I think your trying to do??
Figure out where you want you walls without the brick. It will be built stick frame as the brick is just for looks and siding. It has no structural purpose.
When you know how wide you want your walls, add 3 1/2 inches for the brick footing. When you form out your foundation, you will put a 2x4 flat into your form to create a cavity for the brick to rest on. It will be 1 1/2 inches below the surface of your slab when you remove the 2x4.
After the slab is dry, you remove your forms and the flat 2x4's. Then you frame up your walls on the edge of the slab, but not in the brick footing. Put a sheet of OSB or plywood at each corner on the outside of your framing, then fill in the rest with hard foam.
Don't do the brick work yourself. It takes years and years to be able to lay brick in a straight line. The brick layers will put down a few rows of brick, then use brick anchors to attach it to the studs as it goes up.
When it's all said and done, there will be a gap between the back of the bricks and the stick framing.
Eddie
Thanks Eddie- I didn't make it clear but the veneer is only over the foundation- then it changes to stick frame with Hardiplank siding, so the bottom row of Hardiplank is like 24" above the ground level. So when you look at the house, you see ground, then bricks, then Hardiplank when you look from ground to midwall.
I am hoping to have poured walls for the garage, though I may do block. Either way, I would like it to match the house with transition from brick to siding. I think I will have somebody do the foundation for me.
W
   / How-to ?- foundations #4
In that case, there's no need to pay for full sized bricks. You buy the thin bricks that you put on just like tile. They are made of the same material, but don't have the holes in them to lock them together and are allot cheaper.
With a concrete wall, you just put your morter right on the wall and attach the bricks. It's actualy something that you can do yourself if you go slow and use a level.
No need to do anything fancy with the foundation , but since you are pouring it, you might as well put in a small brick ledge. I'd only make it 1 1/2 inches to give you a starting point to work up from.
Eddie
   / How-to ?- foundations #5
Weesa,
How it's done in PA is to step back the size of the concrete block. For example, if your foundation uses 10" block below grade, you would switch to 8" just before coming above ground level. This gives you a brick ledge that you can adjust to match your intended finish grade. The smaller block would also have the small metal masonry ties sticking out to tie into the brick veneer. I believe three courses of brick equals one course of block. .
PA- I think that is how my house it built...but can this be done with a poured foundation instead of block?
does the sill plate have to be the same width as the foundation? and does the bottom plate need to be the same width as the sill plate?
thanks
W
   / How-to ?- foundations #7
You could put the brick directly on the concrete, as long as the concrete was wide enough for the brick and the walls, usually not a problem. The main difference is the concrete would be a pain to form so it steps up and down to match terrain, if the terrain is graded level then this issue doesn't apply.
I'm not sure if I understand what you mean by the difference between a sill plate and bottom plate, thought they were two names for same thing. Are you saying you have two pieces of 2x wood at the bottom of the wall, one on top of the other, and calling one the sill plate and the other the bottom plate for the wall? If that's the case, it doesn't really matter if the concrete is wider than the wood, the wood just has to be at least the same size as the wall studs. The main concern for having a wider foundation than the bottom plate is that concrete is expensive.
The only time I've seen a wider plate than studs is in some specialized construction using staggered wall studs, i.e. 2x4's on a 2x6 plate, with the studs alternating being flush with the front, and then the back edge of the plate. This is done to give more of a thermal barrier between the inside and outside walls, no wall stud directly connects inside to outside, and you can use thicker insulation.
Thanks for the response...i've attached a rough drawing of what I mean (it is in word format)
It is possible that I do not need the sill plate and the bottom plate, just one or the other. I thought that when we built my fathers garage, thee was were 2 pieces of flat, horizontal 2x between the bottom of the studs and the top of the concrete.
There is also a drawing of a slab-on-grade foundation with a stem wall---is this a possible configuration? The reason I want the stem all is because the house sits on the downhill edge of a hill and I think I would have a problem with drainage. The area that the garage would be is pretty much flat. I had previously built a retaining wall at the edge of the property but I took it back up and I won't have to rebuilt it if I use a stem wall. There is about a 12" different between my lawn and my neighbors lawn. (old picture)
W
   / How-to ?- foundations #9
You may want to get the code requirements from your local building commissioner. I always tend to do that and consider "code" as a bare minimum. I don't have anything that is just to code, but that's just me. I've been accused of overkill. However, I can't possibly stress enough that the foundation is the place to go overkill if you do so anywhere. You only get one shot, and if you undershoot, everything is shot.
My pool house has a concrete foundation that is 24" wide, 24" thick and has 4 runs of #6 rebar on rebar stands inside the footer. I also used 6000 psi concrete with fiber reinforcement for the pour. From there, the exterior walls are 2X8 walls (I get a great amount of insulation in them) with brick exterior all the way up, including the gable ends. My first floor in the pool house is just a concrete slab, but I went ahead and used 6" of 4000 psi fiber reinforced concrete along with 6 gauge wire matting. I almost screwed up too, because the stone floor I have all downstairs is a full 1/2" thick and my plumbing outlets (i.e. the toilet) were almost short after all that.
Anyway, after 4 years, nothing has settled, no walls have cracked, no floors have cracked; even over doors and windows have not cracked any. It really doesn't cost that much to do it right to start. It's only expensive to have to come back and try to brace something up or strengthen something.
   / How-to ?- foundations #10
Those constructions are fine, two bottom 2x are fine, a little easier to assemble the walls on the ground and lift them up in sections and fasten to the sill plate that way. Only critical thing is that the bottom 2x is treated since it's sitting directly on the concrete. I would only recommend that you put a drain pipe and gravel along the base of the wall to keep any water from collecting there and freezing, thereby damaging the wall.
Metal Box with 32 Ratchet Straps (A57454)
Metal Box with 32...
2020 Deere 50G (A53317)
2020 Deere 50G...
CAT930K (A58214)
CAT930K (A58214)
2003 Big Tex 10PI...
F-150 Running Boards (A57454)
F-150 Running...
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
