How to fix a buggered fitting
/ How to fix a buggered fitting #11
Now come on John, why on earth would you take the one way to fix it right and throw out all these humorous rig it ideas?.
You're right, you're right! Sorry I blew up!
How about the JB weld and sell route?
jb
/ How to fix a buggered fitting #12
Any job big or small, do it right or not at all.
Steven, there is no cheap and reliable way to fix most things. Taking it to a hyd shop and having a new bung welded on shouldn't cost you more than 75 bucks. If that's not cheap enough and reliable enough, I don't know what is.
Are you saying that you would charge him $75.00 for you or someone to cut and weld, when he could do the same thing himself? Why not just weld the ORB fitting in place.
Steven, Break out the mig welder and put a bead around the fitting, minus the o-ring.
/ How to fix a buggered fitting #13
There are a lot of things we all could do ourselves. But my guess is that if he took the time to post here and ask for our advice, then he is not comfortable with this whole scenario or he wants it to be done right and problem free. To me, 75 bucks max, probably less as I can't tell unless I had the job here but $75 would be the absolute max I would charge, is cheap piece of mind to me. If you notice, very few cylinder manufacturers or equipment manufacturers run a hose directly into a component. They run to a fitting that screws into a component. This is so that if you are changing hoses, or you break a fitting, or whatever, you can always remove the fitting and install a new one. Weld that fitting in there and it's a bigger problem later. What is he going to do with the next problem? Screw that ORB fitting in there with damaged threads and the pieces of damaged thread that come off go directly into his cylinder. Now by fixing one problem, we create a worse one.
I do like the JB weld idea.
Funny, in this lousy economy, my business is booming because I do the right thing for my customers and they don't have problems. They are tired of all the other shops around here rigging stuff. Thanks to everyone for all their rig ideas, you only make me look smarter. :)
I'm also sorry if I seem abrasive at times, but too many times, I have seen the cheap pay twice. The first time for the rig, the second time to do it right.
/ How to fix a buggered fitting #14
My repairs usually are to get some thing running on a sat or sunday or at midnight most of them have survived we usually order the replacement the next day and it ususlly sits on the shelf till some thing else fails then we change out the repaired part.
For us midnight mechanics bailing wire and string is all whe have. Some times and you learnt to look out side the box like the night we lost a lift pump at our waste water plant lowered the replacement pump in with the riser and it was 1/2" too tall to mate with flange no 3"dies in our plant i suggested we grind 1/2 off pump feet and it has been running that way for 3 years.
tom
/ How to fix a buggered fitting #15
Here is the cylinder off of my boxblade. As you can see, the fitting has experienced some trauma. It didn't leak when the previous owner demonstrated it, but it sure did the first time i tried it.:(
So my question is... Is there a cheap/reliable way to fix this?
Steven
I am thinking that you were deceived by the previous owner for this reason. He knew that it was leaking when using max pressure, like when you run the cylinder to the stops. He probably only used enough pressure to demo the unit. Consider this, that cylinder maybe can lift 1500 lbs, at 3000 psi. To raise a box blade which weighs at around 400 to 500 lb, will not use all the pressure available, so sometime later, you ran it to the stops and developed the high psi and the fitting started leaking.
A new cylinder would be good, but we all don't have the assets. I still say weld it yourself, and if it still leaks, then take it to someone like Wayne County Hose, and they will cut off the bung and weld in a new one. You can also go to Surplus Hydraulics and see if you can locate one that will work.
Wayne County Hose,
All of us are not gentleman farmers, and we don't have the time to run around. We have to use whatever we have, to do the things we do. Do it right, who's to say what is right. Right to a lot of people is does it work. How many of you try and fix your own stuff. Common sense dictates you have to try if you have the knowledge, and ability.
/ How to fix a buggered fitting #16
No disrespect intended to Wayne, because fixing it in the best professional way is no doubt the best way to go.
But JJ and Tom really bring out a good point that all of us face. In many cases, like JJ says, fixing it right has more than one solution. In fact many designs keep that in mind when new stuff is built. that's why some stuff is heavier duty than others. Is it good enough to do the job temporarily, long term or is it going to the moon and back? Fixing it right can be a relative term.
I still like Charles's (farmerford) suggestion the best. I'm pretty sure with and "O" ring seal it will work and seems to be the least amount of work, cost and risk (to me).
/ How to fix a buggered fitting #17
No offense taken here and I hope I didn't offend anyone. I know there is more than one way to skin a cat. The only thing I was looking at was that it came with an ORB port from the factory and when it left my shop, it would still have an ORB port. My goal when I repair something is for nobody to know I even touched it. If my customer says it looks and performs like it did when new, I did my job properly. Just my humble opinion here, but to be able to have it as it left the factory for under 75 bucks is a no brainer.
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
4021 (A59228)
4021 (A59228)
2014 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1EH765285 (A61165)
2014 International...
2017 Ford Expedition 4WD SUV (A59231)
2017 Ford...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62130)
KNOW BEFORE YOU...
2016 Lincoln Navigator SUV (A59231)
2016 Lincoln...
