How to enlarge existing hole?
   / How to enlarge existing hole? #11
A carbide barrel bit in a die grinder will make short work of enlarging that hole by 1/8-3/16" after all you only need to remove 3/32" all the way around. With a carbide bit and die grinder, it wont take more than 5 minutes to do. Be aware of the fine slivers of steel coming off and wear good eye protection and gloves. Nothing hurts more than getting those stuck in your fingers/hand/ God forbid your eyes.
   / How to enlarge existing hole? #12
^^ Doesn't appear he needs to go all the way around, just a small area where the shaft is nearest.
   / How to enlarge existing hole? #13
How about a cutting torch or plasma cutter? You could make quick work of this if you need to shave off just a little bit.
Tools I have at hand:
Compressor (with small die grinder that is probably better used for polishing small items)
1/2" Milwaukee right angle drill
4" DeWalt grinder
7" Dewalt grinder (too bad I'm doing an inside instead of an outside)
I live 15 miles out of town so it's always a pain to find someone to do things
   / How to enlarge existing hole? #15
order off ebay free shipping for your right angle drill a reamer/carbide barrel bit and open that thing up!!!
i live 20 miles out and plan my trips accordingly, grew up 60 miles from anything so i have that ingrained in me to make my trips count not to mention we had little growing up and always scraping pennies.
those bits are cheap, i bought a set from harbor freight and they were very inexpensive use them all the time!!! use it in my cordless craftsman drill they cut very well
   / How to enlarge existing hole? #16
From what I have read all good ideas to enlarge the hole.
Was wonder though, do you have pictures of both the Plate (both sides) and the shaft that goes through it ?
Not that it will change things but just to have a better idea of where you are and what approach "might" be better, pictures can talk if you let them.
Dependent on how critical the hole dimensions are and just how accurate you want the hole to be, the first idea by "gg" sounds the best and cleanest idea... to me ! Yes there is the Machine Shop, either Plasma Cut or Mill the Plate but if things aren't critical a high speed hole saw is quick and efficient.
Making a guide plate to center the hole saw, I've had similar situations and have been caught with my pants down on deciding just how to approach it and now I have a great idea for future events in that arena, thx gg !
Before this the Die Grinder, off the Compressor, worked ok, and a File works but too slow, but a hole saw that you can center on the hole with a jig... to me ingenious !
So I have no suggestions better than what was already used, and my intent of posting was more to get pictures then try to suggest another method, but I found a new way to do my own holes, wood or steel, so I click away from this thread more informed (learned something today) !
Good Luck on the Hole Project, please post up pictures on "where you started" and "where you went" !
Ltr
   / How to enlarge existing hole? #17
Everything mentioned will work.
My choice would be a 1" diameter flap wheel, 36 grit. In your Milwaukee drill. That is exactly my favorite setup for this. It will be almost as fast as the die grinder but creates dust instead of nasty needles that fly everywhere.
   / How to enlarge existing hole? #18
And way more relaxing.
   / How to enlarge existing hole? #19
I've got this 1/2" plate mounted to back of PTO. I mount my mower to it.
The plate has an approximate 4" hole for the 1000 shaft to poke through and and a (don't know the measurement) 1 1/8" hole for the 540 shaft to poke through. It totally fits around the 540 shaft but it gives me the heebie jeebies that one side of it is too close. (I know that as long as it's not hitting, it's not too close but I'd like it slightly further away)
The 540 shaft is (slightly) but noticeably off center. I'd like to enlarge the hole maybe 1/8" to maybe 3/16"
I currently have bracket removed and in my hands.
I was thinking maybe a stepped drill bit?
Reading up on them, people use them for thin metal, wood.... not seen anything about 1/2" steel so it might not be up to the job.
What's best tool to simply ream out an existing hole a fraction of an inch??
:confused3:
If it ain't broke, don't fix it.
   / How to enlarge existing hole? #20
You want to take off so little in one spot...
Mark it with a felt tip marker where you need the material taken off and use a round file like a chainsaw file. Takes a little work but its free.
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
NO TITLE - Utility Trailer (A50514)
NO TITLE - Utility...
2011 Jeep Grand Cherokee Laredo 4WD SUV (A50324)
2011 Jeep Grand...
2022 ISUZU NQR 18FT FLATBED (A51222)
2022 ISUZU NQR...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
Quick Attach Pallet Forks (A47384)
Quick Attach...
