How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench?
   / How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench?
I’m honestly surprised our provider still allows overhead considering they’re responsible for tree damage up to the meter. The jet line takes 10 seconds to pull through with a shopvac and plastic bag. I’ve done it one piece at a time by tying a weight on the line and dropping it through one piece at a time but the shopvac is way easier.
And I understand you run the risk of getting your jetline glued to the inside of your conduit if you do one at a time.
   / How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench? #72
Ok. I am deferring to the power of group think here. Here is my situation. I need to trench 300' for electrical and telecommunication conduit. Electrical is 3" wide conduit and telecommunication will be 2" conduit. The minimum depth for electrical is 30". I am trenching from a pole that is pretty much in the drainage ditch next to the road and up a hill. I am guessing I'll start somewhere around 36" at the pole and be around 3-5' deep when I start ascending the hill. Over a certain number of feet I'll eventually get back up to the 30" (36" to be safe). I think I got that all worked out. Here is my issue. The electrical service is asking for a bed of sand(or stone dust) below the conduit and 12" above. I can't get any answer out of the fiber internet company so I was going to do the same for their conduit. No problem but here is the issue. The telecommunication conduit needs to be 12" away from the electrical. If I dig a wide trench to accommodate both conduits and the spacing, I am looking at a minimum 17" wide trench. Realistically it'll probably be closer to 20". Ok. So what is the problem? The problem is the 12" of sand on top of the conduit. How do I get 12" on top of both conduit and not have to buy a ton of extra fill for the 12" gap in between? I had considered renting a trencher but that might be a little treacherous on the slope and I would need to put a much large gap in the rock wall to navigate through. Plus, being in New England, I'll likely hit some large rocks. Then what? It's not like you can just bend 3" around them or dig multiple new trenches hoping to find a clear path. There is also the fact the electric company only allow a certain amount of bend in the run and I already need to do a 45 degree turn at one point.
A trencher, that can go that deep, is about $310/day from Home Depot. I'd have to do some serious looking to find one somewhat local for cheaper. The easy route is just do the wide trench with the CAT 306 but the cost of filling that 12x12x300 area, in between conduits, is prohibitive.
ever think about renting a ditch witch.
   / How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench? #73
We bought a trencher attachment for the skid steer. Been used for water, electric, and drainage... paid for itself compared to rentals and no time pressure.
2007 Ammbusher DL66 Hydraulic 66in Brush Cutter Skid Steer Attachment (A55973)
2007 Ammbusher...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
2012 International Derrick Digger (A55973)
2012 International...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
