How to determine bolt hardness?
/ How to determine bolt hardness? #1
dfeck
Western, NY
Kubota B3200
Does anyone have any documents that gives detailed information on how to determine the hardness of a bolt?
/ How to determine bolt hardness? #2
Bolt grades are sometimes difficult to determine if you do not have the manufactures box. In GENERAL bolts with no markings are Grade 2, each additional mark is one more. So bolt with 6 "ticks" on the head is a Grade 8. I've attached a link the denotes the grades.
Grade Chart
Thanks for the info! I have bolts that have a reddish appearance. Do you know what this means?
/ How to determine bolt hardness? #4
Would have to see the bolt, but some high grade bolts such as used on aircraft and racing cars have an annodized finish
/ How to determine bolt hardness? #5
Grade 8 bolts have that yellowish, bronze color. In all applications regarding operation of tractors and their attachments it's recommended that Grade 8 bolts be used and at minimum grade 5 (silvery color). Under no circumstances should less than grade 5 be used.
...Bob
/ How to determine bolt hardness? #6
You might want to go by the head more than the color. While I've yet to see a grade 2 bolt that funky bronze/yellow color, I have come across some grade 5 bolts that are. (The store had them labeled as G5 and the heads also reflected the G5 markings.)
Not real sure if you were talking about holding equipment together or not with G8, but I'd tend to agree if that's what you were referring to. Sheer pins (i.e. bolts) are a different matter though as most of the stuff I have requires Grade 2 bolts so that your PTO shaft isn't mangled when overpowering resistance is encountered. The one exception I have is an add-on slip clutch I have for my mower where it specifically said to use only Grade 5.
I suspect I'm a lot like you that if it is a non-moving-hold-it-together situation and I can't find the mfg. specs, I'd too go with the G8. If it's a PTO shaft or something else that uses the bolt as a safety thing, I'd go with a G2 if nothing is specified.
/ How to determine bolt hardness? #7
<font color="blue">...bolts that have a reddish appearance...</font>
Sounds like they are "Metric" Grade...? What's stamped on the end caps?
/ How to determine bolt hardness? #8
I THINK the bolts at the TCS store are color coded blue and red. The red are grade 5 and the blue are grade 8. That also corresponds with the ticks on the head...........
Since I'm at work and the bolts are at home I'll have to get back to you. I'm using these for towing hooks that I'm going to use on my FEL. I picked these up from a bin at my fathers trucking business. I don't think they're metric because I used a 3/4" wrench to tighten them to a piece of angle iron so they can be welded to my FEL. I guess I can ask my father but I know him well enough that he won't know or remember. He's got a ton of hardware and him knowing why he bought these specific bolts are remote. Now that I got the chart I'll check the heads and report back.
/ How to determine bolt hardness? #10
"Grade 8 bolts have that yellowish, bronze color."
That's Cadmium plating you're describing. You really need to go by the head markings...that's about as reliable as you can get without actually metalurgically testing the bolt. There is a flood of counterfit bolts now and then (our less then reputable friends in the Far East along with some greedy scumbags here in the USA provide them).
I've a picture of the headmarkings, but a grade 8 should have a line extending in from each corner of the hexagonal head of the bolt (total of 6 lines). A grade five should have 3 lines extending in from every other corner of the bolt head (again, hexagonal (or 6 sides for you guys that were in the USMC)). Now, those markings are per ASTM and SAE. Therefore, those markings may not be applicable for all manufacturers. I've seen a "filled triangle" on one side or the top of the bolt designating grade 8's.
If I can find the picture of the head marking chart, I'll post it.
Well, I checked the head last night and here is what I seen. No "tick" marks and the only marking is "V108" and across from that "8.8". I haven't had the time to talk to my father but this is now a curiosity issue for me. Any ideas on the markings?
/ How to determine bolt hardness? #13
8.8 is the grade of the bolt, it should also be a metric bolt as well.
Is a metric 8.8 grade in line with an american standard grade 8?
/ How to determine bolt hardness? #15
An 8.8 grade metric is right at a grade 5 SAE.
/ How to determine bolt hardness? #16
Sooooo... Is my metirc 13mm head bolt that is marked 10.8 similar to a REAL grade 8? /forums/images/graemlins/tongue.gif
/ How to determine bolt hardness? #17
If you really want to know how hard a bolt is, many machine shops will have a hardness tester. The markings on the head are no better than the manufacturer. If it's imported from China, be careful about using higher grade bolts in critical applications.
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A61165)
2004 Freightliner...
207278 (A52708)
207278 (A52708)
2019 Chevrolet Tahoe SUV (A61569)
2019 Chevrolet...
LandHonor LHR-SL2T3M 2-Ton Chain Hoist (A60352)
LandHonor...
