How to cut up this fallen tree
   / How to cut up this fallen tree #31
What did you do to your loader to get it to lift that much?
It is rated to lift 1800 pounds to full height. Lifting 2,000 pounds a foot off the ground isn't a big accomplishment.
   / How to cut up this fallen tree #32
The reason I ask is my L4240 is lift to full height (at 500mm) is 1,878 lbs and full height (at pin): 2,489 lbs
   / How to cut up this fallen tree #33
It will lift a good bit more a foot off the ground. My tractor can't lift a ton to full height.
   / How to cut up this fallen tree #34
I've had to do about a million of these. They are a lot of variables to any of these. If what I see can be relied on in the photo, the slope is favoring the weight of the tree. Brush off the dirt near that knot closest to the ball in your pic. Take your 36" bar and make a downward cut. Insert a wedge when about halfway through. Finish the cut. Whether the root ball moves or not is not going to effect where you are standing (highest part of the slope). If you're concerned about saw pinching, you can always shore up the tree just before the cut with a rock or couple of 6x6 dimensional chunks. If none of those were available, we'd make chunks from the stem and jamb them under the tree. You need only do this enough so your saw isn't jammed to the ground.You cut these things with two two thoughts in mind:1. a short enough stump from the ball so as for it to not act as a baseball bat for the cutter should the ball rotate and 2. To leave the stump long enough to give the root ball enough support so it does not tumble forward toward the cutter. I'd suggest making the separation cut first because what you do not want to have happen if you are trimming the tree first is to keep thinking what the tree will do when you finally make the separation cut. This thought will act as a distraction while holding a saw in your hands and that's never good with a running saw in your hands. Get it over with right from the beginning.
   / How to cut up this fallen tree #35
make it into firewood. No one will want to come get one tree. As a forester i have turned some bueatiful wood into firewood!! it makes good easy splitting firewood. One off trees have little or basically no value just due to trucking and labor costs involved with getting it.
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2017 Ford Transit 350 Passenger Van (A59230)
2017 Ford Transit...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
KAWASAKI 42ZV WHEEL LOADER (A60429)
KAWASAKI 42ZV...
