How to clean grease zerks before greasing
   / How to clean grease zerks before greasing #1
BruceWard
Platinum Member
Central, AR
I typically use a stick to clean off the old grease before greasing.
How do you guys do it?
   / How to clean grease zerks before greasing #2
i use a rag before and after to clean up the sometimes spillage
   / How to clean grease zerks before greasing #3
I use a paper towel and a 16d nail to force it into small spaces.
The nail won't break like a stick and it is cheap enough to be a throw-away.
   / How to clean grease zerks before greasing #4
I leave a wad of grease on the nipple when I finish greasing it to keep junk out of the end of fitting and wipe it off with a towel or rag just before I grease it the next time
I use Dave's nail trick or a old screwdriver too to clean out the bad ones like on the bucket pivots that get packed with dirt.
tom
   / How to clean grease zerks before greasing #5
I leave little grease on nipple..clean nipple w/rag also nail trick.
   / How to clean grease zerks before greasing #6
Nobody else uses teeth and twisty straw... huh?
:D
Rag and screwdriver for me too.
   / How to clean grease zerks before greasing #7
Mine usually get cleaned off with the leg of my pants.
I use an ice pick to open the zerk up if it gets sticky.
   / How to clean grease zerks before greasing #8
I pressure wash mine. I spray them down with some simple green, or other degreaser, let it soak a few seconds, the spray them clean. After I let dry a while I pump them full again. I feel that this is only necessary on the bucket pivot points. Mine a always full of dirt and mud. Others I use a paper towel or rag.
   / How to clean grease zerks before greasing #9
What ever happens to be handy, stick, nail, screw driver, with rag. I also keep a box of rubber gloves{doc. nurse type} around easier to get those dirty and throw out then get all over hands. You can find them cheap at harbor freight.
2008 Ford F-250 Ext. Cab Pickup Truck (A49461)
2008 Ford F-250...
2017 Ford Focus SEL Sedan (A48082)
2017 Ford Focus...
8ft x 6ft Container with Side Door (A48837)
8ft x 6ft...
2015 Ford F-650 20ft. Flatbed Truck (A48081)
2015 Ford F-650...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
