How to clean grease zerks before greasing
   / How to clean grease zerks before greasing #1
BruceWard
Platinum Member
Central, AR
I typically use a stick to clean off the old grease before greasing.
How do you guys do it?
   / How to clean grease zerks before greasing #2
i use a rag before and after to clean up the sometimes spillage
   / How to clean grease zerks before greasing #3
I use a paper towel and a 16d nail to force it into small spaces.
The nail won't break like a stick and it is cheap enough to be a throw-away.
   / How to clean grease zerks before greasing #4
I leave a wad of grease on the nipple when I finish greasing it to keep junk out of the end of fitting and wipe it off with a towel or rag just before I grease it the next time
I use Dave's nail trick or a old screwdriver too to clean out the bad ones like on the bucket pivots that get packed with dirt.
tom
   / How to clean grease zerks before greasing #5
I leave little grease on nipple..clean nipple w/rag also nail trick.
   / How to clean grease zerks before greasing #6
Nobody else uses teeth and twisty straw... huh?
:D
Rag and screwdriver for me too.
   / How to clean grease zerks before greasing #7
Mine usually get cleaned off with the leg of my pants.
I use an ice pick to open the zerk up if it gets sticky.
   / How to clean grease zerks before greasing #8
I pressure wash mine. I spray them down with some simple green, or other degreaser, let it soak a few seconds, the spray them clean. After I let dry a while I pump them full again. I feel that this is only necessary on the bucket pivot points. Mine a always full of dirt and mud. Others I use a paper towel or rag.
   / How to clean grease zerks before greasing #9
What ever happens to be handy, stick, nail, screw driver, with rag. I also keep a box of rubber gloves{doc. nurse type} around easier to get those dirty and throw out then get all over hands. You can find them cheap at harbor freight.
Schaeff C30MRF36T189 3,000lbs Stand-Up Reach Forklift (A49346)
Schaeff...
2016 VOLVO SINGLE SLEEPER ROAD TRACTOR (A50459)
2016 VOLVO SINGLE...
John Deere 6430 Side Arm Tractor (A48837)
John Deere 6430...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
UNUSED 12V ELECTRIC PUMP, HOSE & NOZZLE (A50459)
UNUSED 12V...
ATLAS HEAVY DUTY 7' BOX BLADE, 3PT (A50459)
ATLAS HEAVY DUTY...
