How to clean grease zerks before greasing
   / How to clean grease zerks before greasing #1
BruceWard
Platinum Member
Central, AR
I typically use a stick to clean off the old grease before greasing.
How do you guys do it?
   / How to clean grease zerks before greasing #2
i use a rag before and after to clean up the sometimes spillage
   / How to clean grease zerks before greasing #3
I use a paper towel and a 16d nail to force it into small spaces.
The nail won't break like a stick and it is cheap enough to be a throw-away.
   / How to clean grease zerks before greasing #4
I leave a wad of grease on the nipple when I finish greasing it to keep junk out of the end of fitting and wipe it off with a towel or rag just before I grease it the next time
I use Dave's nail trick or a old screwdriver too to clean out the bad ones like on the bucket pivots that get packed with dirt.
tom
   / How to clean grease zerks before greasing #5
I leave little grease on nipple..clean nipple w/rag also nail trick.
   / How to clean grease zerks before greasing #6
Nobody else uses teeth and twisty straw... huh?
:D
Rag and screwdriver for me too.
   / How to clean grease zerks before greasing #7
Mine usually get cleaned off with the leg of my pants.
I use an ice pick to open the zerk up if it gets sticky.
   / How to clean grease zerks before greasing #8
I pressure wash mine. I spray them down with some simple green, or other degreaser, let it soak a few seconds, the spray them clean. After I let dry a while I pump them full again. I feel that this is only necessary on the bucket pivot points. Mine a always full of dirt and mud. Others I use a paper towel or rag.
   / How to clean grease zerks before greasing #9
What ever happens to be handy, stick, nail, screw driver, with rag. I also keep a box of rubber gloves{doc. nurse type} around easier to get those dirty and throw out then get all over hands. You can find them cheap at harbor freight.
Craftsman Pull Type Seeder for Lawnmower (A48837)
Craftsman Pull...
2025 DOWN 2 EARTH GOOSENECK TRAILER (A50459)
2025 DOWN 2 EARTH...
New/Unused Quick Attach Pallet Forks (A48837)
New/Unused Quick...
UNUSED LANDHONOR RATCHET TIE DOWN (A50460)
UNUSED LANDHONOR...
2003 - 1890/1910 Air Seeder and Air Cart (A50397)
2003 - 1890/1910...
377790 (A48837)
377790 (A48837)
