How to check slip clutch?
   / How to check slip clutch? #11
<font color="blue">...seems like alot of work when you could just loosen the bolts a little, let the clutch slip to "clean" the surfaces... </font>
Before, they had “asbestos” material used in the clutch discs and didn’t have this problem of “bonding” or sticking as bad as you do now…
On a four plate slip-clutch it’s much worse versus a 2 plate slip-clutch… full disassembly and reassembly only takes ~~ 15 minutes and you are guaranteed you’ve addressed the “bonding” problem… versus horsing around, loosening, adjusting, testing, retightening, getting on and off the tractor engaging the pto for testing purposes… and still not being sure of the results… /forums/images/graemlins/smile.gif
   / How to check slip clutch? #12
<font color="blue">...How to you get pictures to post within the text instead of just as an attachment?... </font>
Ooopps… almost forgot ya Dan… /forums/images/graemlins/wink.gif
First, the image must be already on a server or previously uploaded… then use the :
{image}image.address.goes.here{/image}
(use [] vs {})
I used the two handsome guys pictures above as illustrations ‘cause I couldn’t find any pretty gals for demo purposes… /forums/images/graemlins/blush.gif
Terminator 3pt 60 Gal Blower Sprayer (A53317)
Terminator 3pt 60...
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
UNUSED WOLVERINE SB-12-72W 72" HDY SCREENING BUCKE (A57193)
UNUSED WOLVERINE...
2017 FECON RTF140 HIGH PERFORMANCE MULCHER (A52705)
2017 FECON RTF140...
Cushman Utility Vehicle Golf Cart (A55853)
Cushman Utility...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
