How to check slip clutch?
   / How to check slip clutch? #11
<font color="blue">...seems like alot of work when you could just loosen the bolts a little, let the clutch slip to "clean" the surfaces... </font>
Before, they had “asbestos” material used in the clutch discs and didn’t have this problem of “bonding” or sticking as bad as you do now…
On a four plate slip-clutch it’s much worse versus a 2 plate slip-clutch… full disassembly and reassembly only takes ~~ 15 minutes and you are guaranteed you’ve addressed the “bonding” problem… versus horsing around, loosening, adjusting, testing, retightening, getting on and off the tractor engaging the pto for testing purposes… and still not being sure of the results… /forums/images/graemlins/smile.gif
   / How to check slip clutch? #12
<font color="blue">...How to you get pictures to post within the text instead of just as an attachment?... </font>
Ooopps… almost forgot ya Dan… /forums/images/graemlins/wink.gif
First, the image must be already on a server or previously uploaded… then use the :
{image}image.address.goes.here{/image}
(use [] vs {})
I used the two handsome guys pictures above as illustrations ‘cause I couldn’t find any pretty gals for demo purposes… /forums/images/graemlins/blush.gif
Lockwood 480 Pecan Harvester (A55315)
Lockwood 480 Pecan...
UNUSED FUTURE STB47 141" TELESCOPIC BOOM (A57193)
UNUSED FUTURE...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A55301)
DeeZee Crossover...
1453 (A57192)
1453 (A57192)
LMC Quick Attach Hay Spear (A56469)
LMC Quick Attach...
