How to calculate winch speed and lift?
   / How to calculate winch speed and lift? #1
valley
Platinum Member
mountain valley near Tahoe
Michigan 55A, Foton 254
I have a cable winch 1300 lb lift. [3" cable roller] cable moves at 1/2 mph
I want to instal a larger wheel on the roller shaft that will move a rope at approx 2-3 mph.
If I use a 9" wheel will it move at 1-1/2 mpr and lift 400 plus pounds?
Maybe because I don't need a dead lift I can use a larger wheel Dia. ?
I don't need a dead lift but about a 45 degree with very little friction.
Does this sound right?
   / How to calculate winch speed and lift? #2
I do not understand the term mpr. Could you explain this unit? I assume you are stating somthing along the lines of feet per minute.
The circumfrence of the pulley (length of bottom layer) is calculated as 3.14 x diameter. A 3" spool would wind up 9.42" per rpm. A 9" spool would wind up 28.26" per rpm. Assuming the winch has sufficient torque to handle the load the 9" spool would spool at 3 times the rate of the 3 spool.
The force the winch can apply halves as the size of the spool doubles. By my math 1.5" (original axis) / 4.5 (9" spool axis) * 1300 = 433 pounds of lift.
I have seen load of a rolling load on a slope caclulated as (degrees * weight / 60 ) . Using this ofrumla your load will be around 75% of the actual weight ignoring friction.
I assume your winch is rated for first level strength and as the cable coils up the winch will become weaker.
   / How to calculate winch speed and lift? #3
the torque on the first example is (1300 * 1.5) = 1950 inch lb
so to put 1950 inch lb on a 9" wheel you need a load of (1950 / 4.5) = 433 lb
if you assume no friction then the 433 becomes 433/cos(45) = 612 lb
the 9" wheel will pull 3 times as fast as the 3" wheel
   / How to calculate winch speed and lift? #4
"the 9" wheel will pull 3 times as fast as the 3" wheel"
AND pull 3 times less weight
Since you mention rope, I presume you are not looking at very much weight therefore you could be OK.
(Poly ropes are kinda elastic, so be careful)
Thanks for the help.
Correction: mpr==MPH
I Want to make a rope tow. So that we, the family, can ski in up back in winter.
This would require having a wheel where the roller is or on the roller.
I would build a cage to house the wench and the outer bearing on the wench shaft.
The grade is about 30%. With skis on there is little friction.
There would be a continuous loop, rope or cable, wench at base and pulley up top.
I was going to use a truck to drive the rope but a wench would make for a cleaner setup.
Any ideas that would add to or help would be great. Thanks for taking the time to think and post.
2025 JMR 78in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 78in Dual...
2024 CHEVROLET SILVERADO 2500 HD BED (A58018)
2024 CHEVROLET...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
Rooster Weathervane (A55853)
Rooster...
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
