How to calculate winch speed and lift?
   / How to calculate winch speed and lift? #1
valley
Platinum Member
mountain valley near Tahoe
Michigan 55A, Foton 254
I have a cable winch 1300 lb lift. [3" cable roller] cable moves at 1/2 mph
I want to instal a larger wheel on the roller shaft that will move a rope at approx 2-3 mph.
If I use a 9" wheel will it move at 1-1/2 mpr and lift 400 plus pounds?
Maybe because I don't need a dead lift I can use a larger wheel Dia. ?
I don't need a dead lift but about a 45 degree with very little friction.
Does this sound right?
   / How to calculate winch speed and lift? #2
I do not understand the term mpr. Could you explain this unit? I assume you are stating somthing along the lines of feet per minute.
The circumfrence of the pulley (length of bottom layer) is calculated as 3.14 x diameter. A 3" spool would wind up 9.42" per rpm. A 9" spool would wind up 28.26" per rpm. Assuming the winch has sufficient torque to handle the load the 9" spool would spool at 3 times the rate of the 3 spool.
The force the winch can apply halves as the size of the spool doubles. By my math 1.5" (original axis) / 4.5 (9" spool axis) * 1300 = 433 pounds of lift.
I have seen load of a rolling load on a slope caclulated as (degrees * weight / 60 ) . Using this ofrumla your load will be around 75% of the actual weight ignoring friction.
I assume your winch is rated for first level strength and as the cable coils up the winch will become weaker.
   / How to calculate winch speed and lift? #3
the torque on the first example is (1300 * 1.5) = 1950 inch lb
so to put 1950 inch lb on a 9" wheel you need a load of (1950 / 4.5) = 433 lb
if you assume no friction then the 433 becomes 433/cos(45) = 612 lb
the 9" wheel will pull 3 times as fast as the 3" wheel
   / How to calculate winch speed and lift? #4
"the 9" wheel will pull 3 times as fast as the 3" wheel"
AND pull 3 times less weight
Since you mention rope, I presume you are not looking at very much weight therefore you could be OK.
(Poly ropes are kinda elastic, so be careful)
Thanks for the help.
Correction: mpr==MPH
I Want to make a rope tow. So that we, the family, can ski in up back in winter.
This would require having a wheel where the roller is or on the roller.
I would build a cage to house the wench and the outer bearing on the wench shaft.
The grade is about 30%. With skis on there is little friction.
There would be a continuous loop, rope or cable, wench at base and pulley up top.
I was going to use a truck to drive the rope but a wench would make for a cleaner setup.
Any ideas that would add to or help would be great. Thanks for taking the time to think and post.
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
202482 (A54757)
202482 (A54757)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
