How to calculate the change in watts if input voltage is changed?
   / How to calculate the change in watts if input voltage is changed? #1
90cummins
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
I have an electric heater space heater with (3) 2.5kw heating elements rated at 7.5kw at 208v that I use for load testing generators. It also has a 208v fan motor that uses 0.6amp.
I would like to calculate the actual load (watts) due to the increased voltage. Various generators operate between 220v and 240v loaded.
I just mated a new L70 Yanmar to a 5000watt head and I want to do an accurate fuel consumption comparison between this diesel and comparable gas units.
I would like a formula so I can accurately calculate loads?
Thanks
90cummins
   / How to calculate the change in watts if input voltage is changed? #2
The basic formula is:
watts = volts x amps
and
volts = amps x resistance
   / How to calculate the change in watts if input voltage is changed? #3
In the heater coils resistance rises as current increases so we don't have enough information to calculate this. You need to use a meter to measure the current (amps) and voltage then it's simple math.
Thanks for the quick reply;
I'll try to measure the watts/amps on 1 leg using my kilowatt meter.
90cummins
   / How to calculate the change in watts if input voltage is changed? #5
and
In the Navy we learned for power.. P=Power, E=volts, I=currant... So, that power formula was easy as ... PIE :)
   / How to calculate the change in watts if input voltage is changed? #6
Here's a list of all the formula's you'll be needing.
   / How to calculate the change in watts if input voltage is changed? #7
For the algebraically challenged, like me :laughing:, we were taught the old finger on the circle trick:
E
I R
I = E/R
R = E/I
E = IxR
I wonder if the power factor varies enough between the various generators to make a significant difference?
   / How to calculate the change in watts if input voltage is changed? #8
Actually in a heater, the resistance is stable with current or temperature. Nichrome, the most common metal used in the resistance wire for heaters only changes resistance by 1% from room temp to 2000 deg F. So if you know the wattage at a given voltage, ohms law can be used to calculate any other value for a given voltage.
In contrast, tungsten used in light bulbs changes its resistance dramatically with temperature. The resistance increases about 0.25% per deg F. Lamps have a high inrush current due to the low cold resistance, but when hot the resistance increases to the "rated" value for the wattage. This is a reason thet many lamps fail at turn on, due to the high current surge and the thermal shock.
paul
   / How to calculate the change in watts if input voltage is changed? #9
paul
Thank you... I learn something new everyday... who says you can't teach an old dog?:)
(3) Rolls of New Barb Wire (A50515)
(3) Rolls of New...
1996 Dodge Ram 3500 (A50515)
1996 Dodge Ram...
JBAR PRM 5 5' ROTARY MOWER (A51243)
JBAR PRM 5 5'...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
Corn Reel (A50514)
Corn Reel (A50514)
JOHN DEERE 250 SKID STEER (A51242)
JOHN DEERE 250...
