How to calculate the change in watts if input voltage is changed?
   / How to calculate the change in watts if input voltage is changed? #1
90cummins
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
I have an electric heater space heater with (3) 2.5kw heating elements rated at 7.5kw at 208v that I use for load testing generators. It also has a 208v fan motor that uses 0.6amp.
I would like to calculate the actual load (watts) due to the increased voltage. Various generators operate between 220v and 240v loaded.
I just mated a new L70 Yanmar to a 5000watt head and I want to do an accurate fuel consumption comparison between this diesel and comparable gas units.
I would like a formula so I can accurately calculate loads?
Thanks
90cummins
   / How to calculate the change in watts if input voltage is changed? #2
The basic formula is:
watts = volts x amps
and
volts = amps x resistance
   / How to calculate the change in watts if input voltage is changed? #3
In the heater coils resistance rises as current increases so we don't have enough information to calculate this. You need to use a meter to measure the current (amps) and voltage then it's simple math.
Thanks for the quick reply;
I'll try to measure the watts/amps on 1 leg using my kilowatt meter.
90cummins
   / How to calculate the change in watts if input voltage is changed? #5
and
In the Navy we learned for power.. P=Power, E=volts, I=currant... So, that power formula was easy as ... PIE :)
   / How to calculate the change in watts if input voltage is changed? #6
Here's a list of all the formula's you'll be needing.
   / How to calculate the change in watts if input voltage is changed? #7
For the algebraically challenged, like me :laughing:, we were taught the old finger on the circle trick:
E
I R
I = E/R
R = E/I
E = IxR
I wonder if the power factor varies enough between the various generators to make a significant difference?
   / How to calculate the change in watts if input voltage is changed? #8
Actually in a heater, the resistance is stable with current or temperature. Nichrome, the most common metal used in the resistance wire for heaters only changes resistance by 1% from room temp to 2000 deg F. So if you know the wattage at a given voltage, ohms law can be used to calculate any other value for a given voltage.
In contrast, tungsten used in light bulbs changes its resistance dramatically with temperature. The resistance increases about 0.25% per deg F. Lamps have a high inrush current due to the low cold resistance, but when hot the resistance increases to the "rated" value for the wattage. This is a reason thet many lamps fail at turn on, due to the high current surge and the thermal shock.
paul
   / How to calculate the change in watts if input voltage is changed? #9
paul
Thank you... I learn something new everyday... who says you can't teach an old dog?:)
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2022 ISUZU NQR 18FT FLATBED (A51222)
2022 ISUZU NQR...
2019 CATERPILLAR 236D3 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
2014 Honda Accord (A50324)
2014 Honda Accord...
74in FEL HD Round Back Bucket (A52128)
74in FEL HD Round...
