How to Bypass the Seat Switch TC34
   / How to Bypass the Seat Switch TC34 #1
forteatwo
There are occasions when I need to stand up on my tractor without the engine stopping. Does anyone know how to defeat the seat switch. As you can see there are four pins. My assumption is to put jumper wires in the slots. The question is which ones to jump.
   / How to Bypass the Seat Switch TC34 #2
Check your owners manual again. Most all tractors have a prescribed method of doing what you want. Without jumpers.
Thanks, I will recheck that. My recollection is the manual states if you put the tractor in neutral and set the parking brake, the seat switch is defeated, and indeed that works. I would like to stand up while the tractor is in gear, being cognizant of the safety issues there. The other problem with the seat switch is if I shift my weight even the slightest amount, the engine cuts out. It is a poorly engineered feature. I confess to being new to all of this however. I just got the tractor.
   / How to Bypass the Seat Switch TC34 #4
I've got a NH 3040, a newer version of the TC40, and these pictures show what I did about 10 years ago. I have had no problems with this setup.
   / How to Bypass the Seat Switch TC34 #5
i duck taped the button down on a mower, worked fine
Unfortunately there is no easily accessible down button, but good thought.
   / How to Bypass the Seat Switch TC34 #8
I REALLY don't understand why some mfg make it so darn difficult. I have a safety alert on my M6040. Stand up or get off the tractor. An alarm beeps for about ten seconds and then quits. Nothing stops - tractor keep running and going. No need to put anything in neutral or set the park brake.
2005 Freightliner M2 106 Ambulance (A56858)
2005 Freightliner...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
2018 John Deere 470G Hydraulic Excavator (A56857)
2018 John Deere...
PAIR OF MINI RUBBER TRACKS (A57193)
PAIR OF MINI...
EZ-GO Electric Utility Cart (A55851)
EZ-GO Electric...
KUBOTA M9000 TRACTOR (A57192)
KUBOTA M9000...
