How to bend 1/4" plate into 18" radius?
   / How to bend 1/4" plate into 18" radius? #11
My scrap yard has tons of short pipe laying around. At .30 per pound, it would be pretty cheap. As stated previously, why not use pipe? It would be perfect and only require torching to get your shape.
I would use pipe but the estimate of $100/ft for 36" pipe was a barrier. If it is 30 cents a pound that would be quite different.
   / How to bend 1/4" plate into 18" radius? #13
The last one I did, i did not bend it in a half circle.
I used a shop press and fomed a bend about 4 in on either side of the center, and let the sides angle up.
I did this with a shop press.
You could also put 3 , 4, or 5 bends in the metal to male your digger..
   / How to bend 1/4" plate into 18" radius? #14
But you only need one foot of pipe. Cut it in thirds and weld them end to end, you'll have a three foot long 120 deg segment of pipe.
I wasn't smart enough to figure that out. Thanks.
I suppose I could get 24" into my press and make a series of bends as you suggest. I'm not sure how long the bucket should be but probably about 36" minimum so maybe I can put in two or three bends on each side of midline with a flat bottom. Might be simpler to just cut the pieces and weld into shape though.
I appreciate all the ideas and experience.
   / How to bend 1/4" plate into 18" radius? #17
What is a stump bucket? How is if used? Anybody have a pic? Thanks.
   / How to bend 1/4" plate into 18" radius? #18
Use a hydralic jack in the middle with a chain secured on each side of the plate and heat it as pressure is applied until it gets to where you want it
BE SAFE!!!!
   / How to bend 1/4" plate into 18" radius? #19
GP,
Did you Google "stump bucket"? We'll help you but we won't spoon feed you.
John
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56438)
Michelin CARGOXBIB...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
