how to: adjust throttle lever 2810 [pics]
   / how to: adjust throttle lever 2810 [pics] #1
Texan4Life
Texas
Mahindra 2810, IH Hydro 70, 706
I have always had an absurdly stiff throttle lever on our 2810 gear. so I finally got around to fixing it.
Take off steering column covers. 3 bolts on the bottom, 2 bolts on top. They are #3 phillips head.
http://i40.tinypic.com/1zv4y6b.jpg
http://i40.tinypic.com/2cggd9f.jpg
Unplug the PTO button so you can get the panel out of your way:
http://i44.tinypic.com/2vbq1oo.jpg
Here can can see the spring controlling the throttle lever tension. 2 bolts hold it to the steering column. remove those.
http://i39.tinypic.com/mm962v.jpg
assembly removed and ready to work on. you can see how the spring is fully compressed!
http://i44.tinypic.com/11brink.jpg
here it is dissembled:
http://i40.tinypic.com/9url8m.jpg
Here it is back together minus one washer:
http://i43.tinypic.com/303h1f8.jpg
And if your throttle was to lose, you can add a washer assuming your large black wear washer was still in good shape.
When I reassembled I added some dielectric grease to the PTO plug. Keeps out moisture and prevents corrosion.
http://i39.tinypic.com/sv6sg8.jpg
I also used some anti seize on the bolts since one of mine was rusted so tight it broke off and i had to drill and tap the nut it screwed into.
   / how to: adjust throttle lever 2810 [pics] #2
Good post !! I'll have to get into my 4110 and tighten 'er up a little. Mine was always stiff for years too but now mine won't hold steady while cutting the grass - the throttle drifts down very slowly and I have to pull it back up every so often while cutting, a little irritating at times. Have been planning to take a look at how it operated but now I know !!
Glad it could help!
I have a PTO seal replacement how to in the works also.
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
John Deere 7130 (A50120)
John Deere 7130...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2021 Kubota KX033-4 Mini Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 Kubota...
