how to: adjust throttle lever 2810 [pics]
   / how to: adjust throttle lever 2810 [pics] #1
Texan4Life
Texas
Mahindra 2810, IH Hydro 70, 706
I have always had an absurdly stiff throttle lever on our 2810 gear. so I finally got around to fixing it.
Take off steering column covers. 3 bolts on the bottom, 2 bolts on top. They are #3 phillips head.
http://i40.tinypic.com/1zv4y6b.jpg
http://i40.tinypic.com/2cggd9f.jpg
Unplug the PTO button so you can get the panel out of your way:
http://i44.tinypic.com/2vbq1oo.jpg
Here can can see the spring controlling the throttle lever tension. 2 bolts hold it to the steering column. remove those.
http://i39.tinypic.com/mm962v.jpg
assembly removed and ready to work on. you can see how the spring is fully compressed!
http://i44.tinypic.com/11brink.jpg
here it is dissembled:
http://i40.tinypic.com/9url8m.jpg
Here it is back together minus one washer:
http://i43.tinypic.com/303h1f8.jpg
And if your throttle was to lose, you can add a washer assuming your large black wear washer was still in good shape.
When I reassembled I added some dielectric grease to the PTO plug. Keeps out moisture and prevents corrosion.
http://i39.tinypic.com/sv6sg8.jpg
I also used some anti seize on the bolts since one of mine was rusted so tight it broke off and i had to drill and tap the nut it screwed into.
   / how to: adjust throttle lever 2810 [pics] #2
Good post !! I'll have to get into my 4110 and tighten 'er up a little. Mine was always stiff for years too but now mine won't hold steady while cutting the grass - the throttle drifts down very slowly and I have to pull it back up every so often while cutting, a little irritating at times. Have been planning to take a look at how it operated but now I know !!
Glad it could help!
I have a PTO seal replacement how to in the works also.
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2009 Ford E-350 Cargo Van (A50323)
2009 Ford E-350...
