How to adjust rear pto clutch 4120
   / How to adjust rear pto clutch 4120 #1
jtfx6552
West Chester, Pa
John Deere 4120
I tried searching... ""adjust pto clutch 4120" brought back 1700+ results in just the JD owning operating forum, went through 5 pages and couldn't find what I'm looking for.
My LX6 mower blades stop in high grass. My pto shaft cover is loose, so I can see it's the PTO shaft that stops turning. I'm packed up to move and can't find my manuals. Is there a way to adjust the clutches that turn the pto output shaft?
Machine is a ehydro if that matters, 2004 with 400 hours.
   / How to adjust rear pto clutch 4120 #2
4120 pto clutch is hyd with no adjustment except changing hyp pressure. It sounds as if slip clutch if so equipped on LX6 is slipping. I Tighten each nut 1/2 turn until clutch stopped slipping.
Thanks! I originally thought it was the clutch in the mower, but since my PTO cover is broken, I can see that the PTO shaft stops at the tractor. Are you saying the clutch isn't really a clutch, but the PTO is turned directly with hydraulic pressure, or their is a clutch pressed together with hydraulic pressure?
   / How to adjust rear pto clutch 4120 #4
The clutch is engaged hydraulically via a clutch valve and series of wet disc and plates. Pressure tests are probably needed to identify the problem if it the tractor that it slipping.
   / How to adjust rear pto clutch 4120 #5
Ditto what Morrisonsteel stated.
Do you happen to know if the gauge port locations, the required pressures and adjustments are shown in the manual that came with the tractor? If so, I'll start tearing into boxes to find the manual, lol.
   / How to adjust rear pto clutch 4120 #7
The op's manual that came with the tractor will not have that information in it, you will need access to a tech manual.
   / How to adjust rear pto clutch 4120 #8
Shoot me your email, I have a PDF of the tech manual you're welcome to
Joe
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
2017 Can-Am Side by Side (A51694)
2017 Can-Am Side...
2011 Nissan Frontier Pickup Truck (A53117)
2011 Nissan...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
2012 Tiger 130BBL Vacuum Trailer (A53117)
2012 Tiger 130BBL...
JLG 1255 Telehandler (A53473)
JLG 1255...
