/ How to adjust draft control to minimum sensitivity on Massey Ferguson 4225 tractor for attachable backhoe?
			#1
			Randalthor
- Joined
 - Nov 13, 2022
- Messages
 - 19
- Tractor
 - Massey Ferguson 4225
As the question states I'd like to know how to position the draft control lever (up or down) for minimum sensitivity.  I have an attachable 3 point backhoe which the manuals state the draft control lever should be set to minimum sensitivity (i.e. heavy).  The owners manual for the tractor doesn't use those terms.  It just explains how to plow using the draft control (i.e. set the position control lever all the way up, enter the work and set the draft control to the desired depth).
I know that the draft control takes into account how much pull the plow is pulling and adjusts the lifting arms accordingly. I also know that to transport a plow, the draft lever is moved all the way up and the position control lever is also all the way up. All that makes sense. I just don't know what is considered (minimum or maximum sensitivity for the draft control lever). I've searched the internet and found conflicting answers.
With a three point backhoe, which has diagonal brackes (like most do) you don't want the lifting arms of the tractor to try to lift up the backhoe, once it's attached. It would bind the backhoe three point linkage, and either break something (very bad) or the hydraulic bypass valve would be engaged (better but still like to avoid). It seems to me you'd want the position control lever in the down position, and the draft control lever also in the down position, so there would be no possibility for the lifting arms to raise.
In other words, if one set the position control lever to the down position and the draft control lever to the down position, there would be no way the lifting arms would lift up, in case one accidentally moved the position control lever up (out of habit) to transport the backhoe. In that case the draft control would still be down, and even though the position control lever was moved up, the lifting arms still wouldn't lift up? Wouldn't that be the safest way to do it?
Your thoughts please.
