How tight should a ball be on a coupler?
   / How tight should a ball be on a coupler? #1
94BULLITT
Super Member
USA
yes
I have a coupler with the trigger style latch. How tight should the ball be? Is there a specification for adjusting it?
   / How tight should a ball be on a coupler? #2
From coupler instructions at:
http://www.northerntool.com/images/downloads/manuals/605660.pdf
With assistance, place the Ball Coupler over the vehicle’s Tongue ball and pull back on the Trigger and push down on the Handle until the Trigger locks in the slot. Pull up and down on the Ball Coupler to make sure the Tongue ball is fitting snugly in the Ball Coupler. There should be no play between the Tongue ball and the Ball Coupler
CAUTION: If there is play, tighten the Adjustment Nut until no play is present. If the Adjustment Nut is too tight, the Handle will not lock. Failure to properly adjust can result in uncoupling. After the Adjustment Nut is properly adjusted, pull back on the Trigger and push down on the Handle until the Trigger locks in the slot. Pull up on Handle firmly to make sure the Trigger is locked in place and the Handle cannot move.
Thanks, Bruce. Thats was how I adjusted it. The funny thing is I adjsuted it to the pretty much new ball on the truck. It is extremely tough to latch on the tractor. The ball on the tractor is older. I guess there may be different size 2" balls. Atleast now I know I adjusted it properly.
2016 Ford Expedition XLT 4WD SUV (A59231)
2016 Ford...
2019 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A60429)
2019 CATERPILLAR...
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
