How the Ford 8N was customized with non-tractor engines
   / How the Ford 8N was customized with non-tractor engines #22
I was just doing some reading on the Funk brothers engine swap business. It sounds like there were 3 options- 226 CI flathead 6, 215 CI OHV 6, and the flathead V8. It looks like the flathead v8's never really caught on. I'm guessing the primary reason was increased fuel consumption? I can imagine they would be very good at PTO work.
   / How the Ford 8N was customized with non-tractor engines #23
The 8n was the VW bug of tractors?
   / How the Ford 8N was customized with non-tractor engines #24
Thanks for posting Ed. Cool stuff. This has got to be the first time I ever saw an 8N with a Honda engine! LOL
There is a restored 8N in my area I have been trying to buy that has a Canadian flathead V8 in it.
I just read those Honda's were 118 hp and 125 ft.-lb. of torque
Gonna add one more conversion. This one done by a buddy of mine out in Montana. 302V8, but has something none of the others have.......a drag chute and a roll bar....LOL!
   / How the Ford 8N was customized with non-tractor engines #27
you guys might find this website interesting, but you'll have to removes the spaces between letters, TBN doesn't like the web address.
https://www.n tractor club.com/forums/manuals/manuals.htm
   / How the Ford 8N was customized with non-tractor engines #28
I have learned so much from the good people at N tractor club, and have printed out a lot of the manuals as well. They now live forever in my service records!
There's another 8N in my area that is pretty optioned-out, it has a Dearborn 19-23 loader and a Sherman Power Digger backhoe unit, along with some sort of gear-reduction auxiliary transmission. If I recall correctly, it's just an underdrive unit, no overdrive. Every now and again the owner uses it to clean out irrigation ditches. It's a handy little machine, but not very effective until after a good rain softens the soil.
This optioned-out 8N is owned by a guy over in the next county from me. It's got a 60HP flathead V8, Sherman Combo auxiliary transmission, power steering, and a Howard gear reduction unit behind the transmission. The Howard was intended to be paired with the company's Rotovator (tiller) and slowed the 8N down enough to use this implement more effectively.
   / How the Ford 8N was customized with non-tractor engines #30
The Howard was a good addition to the N tractors however it also added a weakness to the tractor. The gears and frame that supported the gears was not able to stand up to much abuse. As long as it was steady pulls it would do OK but if the operator got to jerking against it on a pull it had a tendency to split the support holding the main reduction gear. Much like the Funk conversions increased horsepower would break the rear pinion support and bearing in the differential. Smooth and steady pulls they did fine but repeated jerky or shock loads would do them in.
I saw an ad for a Howard gear reduction just the other day but cannot remember where it was now... they were asking a $1000 for it. I would have given it some serious consideration if I had a trailer queen.
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
Volvo A40D Off Road Dump Truck (A56438)
Volvo A40D Off...
Toro Zero-Turn Commercial Mower (A56857)
Toro Zero-Turn...
HAMM H11 PADFOOT ROLLER (A58216)
HAMM H11 PADFOOT...
Post Driver (A57454)
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
