How strong would channel iron be if ?
   / How strong would channel iron be if ? #1
aldanbnb
Battle Ground In.
Same, Gravely, Wheel Horse
Hi
This is going to sound a bit odd but,
What I have is a bent Bobcat attachment plate that I have straightend.
To keep it from bending again I am going to try welding a couple of pcs. of 8" x 1/4" channel on.
If I weld the legs to the flat plate how strong is that going to be ?
I was wanting to use 4" x 1/4" square tube but cannot find any used cheap. That would have been as strong as I need, I think.
Thanks
   / How strong would channel iron be if ? #2
I think you may be missing a dimension on the angle iron. Are the pieces 8" long by 1/4" thick? What is the width of the angle iron?
   / How strong would channel iron be if ? #4
Channel, not angle.
My mistake. If 8" wide channel and 1/4" thick this would be standard grade not structural grade. It would add strength to the flat bar more than double the flat bar alone.
Thanks guys
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
DoD 88-20041 12.5kVA Brushless Diesel Generator (A51691)
DoD 88-20041...
2018 HINO 195 16FT BOX TRUCK WITH LIFT GATE (A53426)
2018 HINO 195 16FT...
UNUSED FUTURE 19" EXCAVATOR RAKE (A51248)
UNUSED FUTURE 19"...
2020 BERGMANN C815S DUMP TRUCK (A51246)
2020 BERGMANN...
