How strong would channel iron be if ?
   / How strong would channel iron be if ? #1
aldanbnb
Battle Ground In.
Same, Gravely, Wheel Horse
Hi
This is going to sound a bit odd but,
What I have is a bent Bobcat attachment plate that I have straightend.
To keep it from bending again I am going to try welding a couple of pcs. of 8" x 1/4" channel on.
If I weld the legs to the flat plate how strong is that going to be ?
I was wanting to use 4" x 1/4" square tube but cannot find any used cheap. That would have been as strong as I need, I think.
   / How strong would channel iron be if ? #2
I think you may be missing a dimension on the angle iron. Are the pieces 8" long by 1/4" thick? What is the width of the angle iron?
   / How strong would channel iron be if ? #4
Channel, not angle.
My mistake. If 8" wide channel and 1/4" thick this would be standard grade not structural grade. It would add strength to the flat bar more than double the flat bar alone.
Thanks guys
2005 DIVERSIFIED FABRICATORS FERTILIZER SPREADER (A51247)
2005 DIVERSIFIED...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
UNUSED FUTURE FT13J EXCAVATOR (A51247)
UNUSED FUTURE...
HURRICANE 7' X 12' CONTAINER (A51248)
HURRICANE 7' X 12'...
2015 Ford Explorer SUV (A51694)
2015 Ford Explorer...
2023 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2023 KOMATSU...
