How should I fix this??
   / How should I fix this?? #1
yelbike
Near Winnipeg, Mb, Canada
John Deere 2305, 2320,Z465
The seat cover has come unglued from the base all the way around. What kind of glue should I use? How should I clamp it during cure time or should just replace the seat entirely?
Thanks in advance.
   / How should I fix this?? #2
If it can be glued at all, CONTACT CEMENT is the right material!
No clamping required.
I like Weldwood brand.
PRACTICE in something else first!
   / How should I fix this?? #3
Contact cement, yes.
Also you can use a heat gun to soften the leatherette to make it obey.
Numerous clamps will also be your friend.
   / How should I fix this?? #4
My wife would hand me the duct tape and expect me to be happy with it.
Just make sure the mating surfaces are very clean and allow the correct drying time after you coat the surfaces with the contact cement. Contact cement doesn't give you a second try if you don't get it right the first time.
TMA (A49461)
TMA (A49461)
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2014 Chevrolet Tahoe (A50324)
2014 Chevrolet...
