How should I fix this??
   / How should I fix this?? #1
yelbike
Near Winnipeg, Mb, Canada
John Deere 2305, 2320,Z465
The seat cover has come unglued from the base all the way around. What kind of glue should I use? How should I clamp it during cure time or should just replace the seat entirely?
Thanks in advance.
   / How should I fix this?? #2
If it can be glued at all, CONTACT CEMENT is the right material!
No clamping required.
I like Weldwood brand.
PRACTICE in something else first!
   / How should I fix this?? #3
Contact cement, yes.
Also you can use a heat gun to soften the leatherette to make it obey.
Numerous clamps will also be your friend.
   / How should I fix this?? #4
My wife would hand me the duct tape and expect me to be happy with it.
Just make sure the mating surfaces are very clean and allow the correct drying time after you coat the surfaces with the contact cement. Contact cement doesn't give you a second try if you don't get it right the first time.
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
Killbros 250 bu Gravity Wagon (A50515)
Killbros 250 bu...
2006 International 4400 LP Ambulance (A50323)
2006 International...
2020 EZGO GOLF CART (A50324)
2020 EZGO GOLF...
10 Ft Fork extensions (A50322)
10 Ft Fork...
2012 Chevrolet Cruze LS Sedan (A50324)
2012 Chevrolet...
