How often to grease?
/ How often to grease? #21
chrisjbell said:
Better to put too much grease on something than too little.
Untill you push a seal out and a bearing dies...
"just enough' is the right amount.. not too much..:D
soundguy
/ How often to grease? #22
How do you tell if black grease is dirty?? Red and tacky I can see the dirt.!!!
/ How often to grease? #23
soundguy
So, what are you saying here? Just go very, very slow unitl a tinsy bit comes out or what?
/ How often to grease? #24
saparks10 said:
There is no one answer for how often to grease. How often and how much depends on the application (load, environment, temperature, speed) I will say that over greasing is one of the most common reasons for bearring failure. Bearrings simply need friction to roll. When to much grease is used the bearring cannot role and sliding friction happens, versus the rolling friction. Anyone ever seen bearrings with flat spots on them?
I tend to agree with most of what you said. I have been told that over greasing is a bad thing . I think that one of the reasons is that the manufactures put a grease fitting on just about everything, even on spindles with sealed bearings. I would suggest that most people do not know what kind of bearing that is installed in the equipment, and think that more is better. How many of you have seen a bearing fail with grease bulging out all over. Some people even go so far as to punch holes in sealed bearings to put a needle injector in and give it a couple of squirts. A lot of people seem to forget that gobs of grease collect grit, and as the bearings turns, some of that grit is entering the bearing, and that good grease is now bad grease. How many of you have lost a grease cap off a trailer axle, and the only way you knew was from the smoke coming from the burnt bearing, or the hub with tire just came off. If you look on the Internet for types of bearings, and bearing failures, and over greasing, you will find lot of data.
/ How often to grease? #25
That's the genaral rule ?
/ How often to grease? #26
Z-Michigan said:
This doesn't make a lot of sense to me. I can see how a too-slippery lubricant might prevent roller or ball bearings from rolling, but frankly, if it's that slippery than what damage will be done by sliding without rolling? Also, most grease points on my tractor are in areas with plain bearings and not roller or ball bearings. There's nothing to roll in a plain bearing, and too much friction creates a spun bearing = instant pricey repair.
It doesn't make sense because it's a myth. The first place I heard this "theory" was many years ago when Harley mechanics were blaming their crank bearing failures on synthetic oil, claiming it was "too slippery for the bearings." Of course it ended up being just low quality bearings in the low quality engines they were working with but the myth remained.
Fact is, if there's so little load and friction for a bearing to roll, there's too little of each to do any damage.
The "just touching on a single point" addition to this myth we've seen in this thread to explain further is also not possible. Quality bearings are ground to such precision tolerances that if "a single point" is touching the whole roller or ball is touching. The only way that couldn't happen is if the bearing was such poor quality it wasn't round in the first place.
/ How often to grease? #27
J_J said:
bearing that is installed in the equipment, and think that more is better. How many of you have seen a bearing fail with grease bulging out all over. .
I cant say that I have ever seen one fail from too much grease
I'd be willing to admit that I've seen em fail because they were never greased
also be willing to admit that I've seen them fail because somebody blew out the grease seal which allowed foreign material to do its thing, but I just cant say I've ever seen a bearing fail because it had too much lubricant.
/ How often to grease? #28
that aint the general rule, there is no general rule, for instance universal joints in need to be greased unti the old stuff is purged from the trunnion as evidenced by clean grease coming from all four seals
/ How often to grease? #29
How about this, go very very slowly until a tinsey bit of clean grease comes out...then you know you've pushed all the dirty stuff out.
When this thread was started the original poster stated that he had 48 grease fittings and I figured I prolly had somewhere in that area, so I bgt an air grease gun...don't want carpel tunnel ya know:eek: . Now I got my service manual and it looks like I only have about 9...so I'm a happier camper. I can go slower on 9 than I could on 48 :D
/ How often to grease? #30
Well, if it is a myth, then it is a myth that my cousin (by marriage) believes as well. So, why would that be relevant? He is the Quality control engineer and testing branch supervisor for INA / FAG bearings in Germany.
That said, when he took me on the tour of the testing and R & D department, we discussed it at length, and like so many other things the real answer is "it depends"
One of the particular questions I had for him, and we discussed in detail, is our practice of taking the seals off the bearings on our dirt bikes, and packing the bearing plumb full of grease and then popping the seals back in.
We do this, in the thought that it is better to have it plumb full of grease, then to have the customary amount of void or airspace in the bearings.
He then brought up the sliding of the rollers, explained that the type bearings we were using were "stock" or "catalouge" bearings made to fit a wide range of uses and for our particular application it was probably a wise choice. We were probably more likely to experience bearing failure from dirt, crud and water then from the bearing sliding instead of smoothly rolling.
He then went on to point out that those bearings were originally intended for high speed electric motor applications where that small, precisely measured amount of grease was determined to give them their best life for their average expected use.
Then he took me into the room where they were currently running tests to determine optimum lubes, rates, etc. etc. of running bearing's to failure.
So, is it a myth, not in my opinion. Does someone take something out of context and apply it where it should not have, happens often, and as I often say at work, why is it so hard to get out good information while bad information can spread like wildfire.
In the FWIW category, I doubt seriously you could overlube any bearings found on my ag or construction equipment.
I am in the lube it till it comes out, wipe off gross excess yet leave some to form a sheild on open bearings / pivot pins, and on closed or sealed area's try and put a very small amount in till you believe it has recieved grease and not so much as to break the seal.
/ How often to grease? #31
Of course the answer is "it depends." I agree 100% that the context and details are everything.
I wasn't arguing that it wasn't possible to get ball or roller bearings to "slide" or "skid" or that the wrong quantity or type of lubricant wouldn't lead to premature bearing failure, I only take exception to the "too slippery to roll" statement along with the others we've seen describing how the bearing might have only a small contact point instead of the full ball or roller etc.
Out of curiosity you might ask your brother in law if he's ever seen a case where they used a higher friction lubricant, or added something like a friction modifier to a lubricant to increase a bearings life by making the lube less "slippery." That, as opposed to using a different viscosity or quantity of lube.
Everything I've seen or read says there are lots of ways to make bearing fail, but a lubricant with too little friction isn't one of them.
Too much or too little lube, especially in high speed bearings will generate heat and shorten their life.
A lube to viscous or too thin will shorten their life. A too viscous lube or too much might even lead to the rollers sliding or skidding especially with rapid increases in load or speed since the drag of the lubricant has to be overcome by the ball or roller.
And there are lots of other ways to shorten bearing life, like rapid load increases or impacts. We have some high speed fans here that weigh less than an ounce and have an average life of 50K-80K hours. When they fail it's the bearings that are the problem, not anything electrical. But drop them once from a height of a couple of feet and the bearing life will be under 3 months.
In any case, I don't think many of those things apply to the equipment we use and I agree with you as to how it should be greased.
And sure, all of this is somewhat pedantic but accepting things like the "too slippery" statement as truth will often mask the real failure mode. Pretty soon you're thinking heavier things drop faster than light ones because that's what happened the last time you threw a pool ball and a feather out the window...
/ How often to grease? #32
How much and how often to grease is not a simple answer. It depends on the type of bearing, application, speed, heat, type of grease, sealed or not sealed, etc... On high speed bearings over greasing can lead to bearing failure faster than lack of lubrication. In high speed applications over greasing can cause bearings to over heat and fail within the same day. Now considering that there really are not any high speed electric motor type bearings on your standard tractor the risk of over greasing is very low. You could possibly damage a seal if you were to grease to much but even then the chances are small.
Sealed but greasable type bearings need far less lubrication than open non-sealed bearings and bushings. FEL and BH pins and bushings are a good example. No seals and extremely dirty conditions in this situation would call for more frequent lubrication. The higher frequency of lubrication will help to purge out any contamination that has entered the pins and bushings. On areas that are exposed to high contamination leaving a little grease on the outside can actually be a good thing (note I did not say globs or a huge mass of grease). The layer of grease on the outside helps by actually forming another barrier to contamination entry.
To slippery a lubricant, doubtful. The only instance I have seen case study's on about real world problems with a lubricant that was to slippery was in diesel engines and the use of synthetic oil. Some "rare" cases of cam gaulling have been documented and associated with some types of synthetic base stock. Nothing to get all concerned over, synthetic will not destroy your engine. It's the only thing I can think of that related to a lubricant that was to slippery.
Now you can have a grease that is to tacky. In high speed motor bearings a grease that is to cohesive will tend to form a wave front in front of the roller bearings thereby starving the rollers of lubricant. Once again though you won't find this type of bearing on tractors.
Probably the best advice is use common sense. If your pounding your tractor to death then it will need to be lubricated more often. Light slow speed use will require less frequent relubing.
/ How often to grease? #33
I had an old British motorcycle (53 BSA), a low rpm torquy thumper. It clattered like mad. The rods and I think mains were needle bearings. I swear you could hear every needle at low rpm.
I've always wondered why they chose needles for the rod bearings. I would have thought the concentrated spot forces would be enormous every time the cylinder fired, and a plain bearing would transfer that stress to the oil film better. But it worked fine.
/ How often to grease? #34
Hi Guys.. I am novice when it comes to my ( New to me ) 1984 Ford 4110 Tractor.. I have no idea where to grease her nor how often I should..
Yes I know that makes me dumb .. but with a little help from this wonderful braintrust here.. I hope to learn enough to not make too many mistakes.
I don't know where to look for the greasse nipples.. and I don't know how to attach a grease gun to them. BUT .. I did buy a grease gun and some grease..!! so maybe I am only half as dumb as I think I am ? I use a Slasher ( bought New) at the moment and not a lot else as I am broker than a three dollar watch in a collectors throw away bin!
Bob
/ How often to grease? #35
Now is a good time to get very familiar with your new tractor. :)
Anything that moves needs grease usually. The steering linkage, clutch and brake linkage, front axle pivot, things like that. I'm not familiar with that model.
Look under, around, over and through for grease zerks or places that could use a dab of grease or oil. You just push the grease gun nozzle onto the zerk, then pump grease, pull it off and go to the next one. The grease gun nozzle may have a sliding tube section that you can pull back on to allow getting it on zerks that are tight fits.
/ How often to grease? #36
1-2 pumps per 10 hours of work/day is sufficient. Pumping good grease out is a waste and is messy. Furthermore, when you work pins or bearing, more grease will squeeze out when you work it making more of a mess.
/ How often to grease? #37
if it is new to you and you are using a different type of grease than the PO.. I'd grease all the joints and push out the old grease till you see your new grease. once there.. then yeah. a couple pumps per days work.
/ How often to grease? #39
At the end of the day when I'm finished with the tractor, I grease all the grease points on the tractor and loader
/ How often to grease? #40
I grease my TC45A every 25 hours. My NH manual says every 50 hours. (I don't have a loader o my tractor)
My brush hog I grease every 6-8 of use.
2001 GMC C7500 Fuel Truck (A62613)
2001 GMC C7500...
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
Parker 500 Auger Wagon (A66285)
Parker 500 Auger...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
2025 Bobcat T650 (A64126)
2025 Bobcat T650...
2022 EZ-GO ELITE...
