How Often do you shrapen your blades?
   / How Often do you shrapen your blades? #21
Call me crazy but I take a 7018 welding rod and put a hard surface on all my blades, then I just sharpen them after every use. I still get a good cut and a good finish on mine.
hope you ain't got bystanders when cutting grass, etc. ... them superhard blades lose an argument with a stubborn rock or steel rod and they is apt to be pieces of mower blades flying about like shrapnel... JMHO.
   / How Often do you shrapen your blades? #22
Seems he's just putting "hard surface" on them. The blade should still be as brittle or not as the original blade. 7018 isn't exactly a hard surfacing rod so it appears he's just putting metal on the cutting edge, then grinding that instead of the blade. Though i wonder about the heating effects on the blade body.
   / How Often do you shrapen your blades? #23
I'm no metallurgist, but have done enuff lab testing on mower blades to appreciate the strict engrg/safety specs involved relative to grain structure, hardness, ductilility, ad nauseum. The 90 degree bend test around a one inch dia rod w/o any cracks is tuff to meet all by itself..... :)
   / How Often do you shrapen your blades? #24
Main thing is, I make sure my yard doesn't have any steel rods or rocks in it, it works well for what I do, plus I don't run a small mower, 72" turf tiger
   / How Often do you shrapen your blades? #25
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=324345"/>
Here is a picture of the high lift blades used in the 54 inch deck.
Bob B.
Here's a picture of mine. Big difference in weight and thickness I'm sure.
   / How Often do you shrapen your blades? #26
What size deck are those from? I don't think they have quite as much lift as mine but definitely look more durable.
Bob B.
   / How Often do you shrapen your blades? #27
Bob B.
They go on a mmz2554 54" cut. They are high lift. Very thick and heavy. They fit the 54 Tank and the 54" MTD Pro which are one of the same.
   / How Often do you shrapen your blades? #28
I have 2 sets so I usually sharpen both at least once a season. I still use the original set when I bought my Cub in 2003. I have a set of Hi-Lift blades and they work great with the triple bagger. Both set show no signs of cracks or broken off wings
   / How Often do you shrapen your blades? #29
I usually sharpen mine once at the beginning of the season.
But I am also using the gator G6 blades that have bits of sintered tungsten along the bottom of the cutting edge. So they dont dull very quickly. An I run over lots of dirt clods, mole hills, and sticks that I am too lazy to pick up. I also keep the trails in the woods mowed, so lots of twigs and sticks there too. All in all about 2 acres of mowing once a week.
   / How Often do you shrapen your blades? #30
I probably have about four mulching blades for my 33" Snapper Yard Cruiser, so it's easy to keep at least one sharp and ready to be installed. I change the blade maybe three times a year. I put a non-mulching blade on in the fall (I have a few of them, too), which is better for picking up the leaves (which if mulched get carried in by the dogs...).
A sharp blade cuts better and puts less of a load on the mower itself. I thinks it's hard to not change them too often.
3410 (A47477)
3410 (A47477)
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Milwaukee Box with Electrical Supplies (A57454)
Milwaukee Box with...
2011 Ford F-150 Crew Cab Pickup Truck (A56858)
2011 Ford F-150...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Concrete Grinder (A57454)
Concrete Grinder...
